Author Topic: Anyone considered a 16v mTDI?  (Read 9976 times)
Reply #15April 30, 2013, 02:39:34 pm
Re: Anyone considered a 16v mTDI?
« Reply #15 on: April 30, 2013, 02:39:34 pm »
it would probably be easier to convert a 16v gasser head to accept a TDI injector, than it would be to use a PD/CR head..
why cant we build a PD to run like a detroit diesel? they didnt have an ECU, and had cam-operated injectors.. the injectors on a PD are likely all electronically operated? was such thing as a M-PD?
do you feel that your engine doesnt breathe well enough andrew? have you ported the head yet? a few users on here have had AWESOME increases from a good port job on even a 1.6 head.. the 1.9 head yields better numbers yet..
from a cost stand point, i think that a set of under-cut valves, and a good port job are going to net you a larger increase than an engine combo that may or may not work..
just because the head bolts on, doesnt mean it will work.. i believe they changed the later TDI blocks as well.. remember reading that the later TDI blocks had more oil drains, and more coolant passages as well..
i dont know if the 2 blocks are close enough to work tho..
Reply #16May 01, 2013, 04:53:23 pm
« Reply #16 on: May 01, 2013, 04:53:23 pm »
I have not ported any of my TDI engines.  Do they 'breathe well enough'?  Sure.  Would 4 valves per cylinder increase their ability to breathe well?  Absolutely.  I do not think starting with a gasser head would make for less work.  I am not thinking of mixing and matching heads/blocks.  I would use the full CR longblock, bolt on the ALH pump bracket where the high pressure CR pump is, fit a custom intake and injection lines and modify the head/injectors to fit.
Reply #17May 01, 2013, 04:55:11 pm
bbob203
  • 1789
« Reply #17 on: May 01, 2013, 04:55:11 pm »
And then a standalone vnt?
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #18May 01, 2013, 06:37:46 pm
« Reply #18 on: May 01, 2013, 06:37:46 pm »
Standalone electronic VNT control will be completed before putting any serious consideration into an mTDI CR engine.
Reply #19May 02, 2013, 07:31:27 pm
rabbid79
  • 684
« Reply #19 on: May 02, 2013, 07:31:27 pm »
Hi Andrew,
If you have the technical savvy to build an electronic VNT control, I'll bet you could also design a simple stand-alone electronic fuel injection control system for this engine.  I'm not saying it would be anywhere near as refined as a factory ECU, but if your only goal is drivability, fuel efficiency, and emissions that are on par with a mechanical fuel injection pump, I'll bet it wouldn't be too bad.
« Last Edit: May 02, 2013, 09:05:38 pm by rabbid79 »
'15 WRX
Reply #20May 03, 2013, 01:55:50 pm
« Reply #20 on: May 03, 2013, 01:55:50 pm »
The time you'd save by buying a Bosch motorsport ECU  might be worth it though.
Reply #21May 03, 2013, 03:19:08 pm
« Reply #21 on: May 03, 2013, 03:19:08 pm »
While I enjoy the bells and whistles of a stock eTDI, on a conversion I'd rather run a mechanical pump for the added reliability, easier install and easier tuning.
« Last Edit: May 03, 2013, 07:48:31 pm by libbydiesel »
Reply #22July 04, 2013, 07:59:01 am
bbob203
  • 1789
« Reply #22 on: July 04, 2013, 07:59:01 am »
Libby you ought to check out the injectors for V6 tdi they might work for this. I was reading some uk forum where a guy made a v6 mtdi and looked interesting.
03 Jetta wagon TDi
Reply #23July 04, 2013, 08:11:03 am
bbob203
  • 1789
« Reply #23 on: July 04, 2013, 08:11:03 am »
03 Jetta wagon TDi
Reply #24July 04, 2013, 12:26:02 pm
« Reply #24 on: July 04, 2013, 12:26:02 pm »
Right on.  Thanks for the link.  That guy does some crazy stuff.
Reply #25September 24, 2013, 06:21:13 am
bbob203
  • 1789
« Reply #25 on: September 24, 2013, 06:21:13 am »
Bringing this one back here is an old thread i found.http://www.vwdiesel.net/forum/index.php?topic=18624.0
This whole idea seems cool to me.
03 Jetta wagon TDi
