extra line from or to injection pump
Topic: extra line from or to injection pump (Read 2697 times)
April 09, 2013, 10:53:20 am
Blue Haze
User+
82 caddy w/AAZ 1.9 motor 5spd w/ A/C
April 09, 2013, 10:53:20 am »
After my installer put in my 1.9 AAZ motor I noticed an extra fuel type line not connected to anything it goes back to the fuel fill above the tank. I believe that it a vent line but not sure. Does not seem to effect the running of the engine; however, it is hard to get to fire off after it has sat for any length of time. Where should this connect on the injection pump?
April 09, 2013, 02:09:09 pm
Re: extra line from or to injection pump
April 09, 2013, 02:09:09 pm »
What engine did you have in there before? Can you take a picture of both ends of the line and what they are hooked up to presently?
April 09, 2013, 03:57:47 pm
Blue Haze
User+
April 09, 2013, 03:57:47 pm »
I had a 1.6 NA motor in there previously. The one end is connected to the fill pipe to the fuel tank and the other end is presently open not connected to anything.
April 09, 2013, 04:35:21 pm
April 09, 2013, 04:35:21 pm »
There is only three fuel lines on any of these injection pumps. One large one near the pulley, another large one at the other end or on top, and a small one that meets this last one as well coming from the injectors.
I don't know what vehicle you are driving (please take the time in the profile to add what car you drive so it will be easier to troubleshoot in the future.) If it is mk1, then that is probably definitely more than likely a tank vent lol
April 09, 2013, 08:46:57 pm
Wayland
April 09, 2013, 08:46:57 pm »
MkI diesels have a vent line coming from the tank that disappears into a hole in the front member next to the engine on the pass. side.
84 Grumman Olsen Kubvan
93 Dodge CTD Truck
