Author Topic: Deciding on parts for my turbo setup  (Read 8429 times)
April 04, 2013, 06:26:08 am
Rising
  • 385
« on: April 04, 2013, 06:26:08 am »
Ok so I want some feedback on the best way to go about this whole turbo setup. I've been trying to slowly collect parts for this build, but now I'm starting to wonder about some of my parts and maybe it would be better to sell some of these and start over.
I have a vnt15 with integrated manifold, egr has been cut off and welded shut, and a gasser intake manifold with no throttle body. I have a 1.6TD block with oil squirters etc, but a N/A pump and oil pan.
I've heard the vnt is a great turbo for the 1.6, and I think especially using a N/A pump, the instant boost would allow me to run more fuel since "off-boost" really wouldn't be an issue.
But I also know that the mechanical linkage would be difficult to fabricate and I'm not sure if the 18.5 PSI max on the VNT will get me to the 100-115whp I'm looking for. But at this point I'm just tired of my 58HP and want to get at least some kind of turbo setup running.
Should I just sell the VNT and gasser manifold and just get a stock turbo setup instead of fabricating my own exhaust, intake, and mechanical vnt controller? Or is it worth it and I should stay the course?
'84 Rabbit Diesel- 1.6D Stock
Reply #1April 04, 2013, 07:08:37 am
Re: Deciding on parts for my turbo setup
« Reply #1 on: April 04, 2013, 07:08:37 am »
vnt is an awesome turbo on a 1.6 and should do your power goal easily, u might just need a smaller intercooler. but the stock setup is nice cause if you get one complete then you should be able to have it installed in a saturday pretty easily.  the vnt is going to be harder to install and setup but the result will be better.
Reply #2April 04, 2013, 07:11:43 pm
« Reply #2 on: April 04, 2013, 07:11:43 pm »
I agree, if I find a VNT local for cheap I will be pouncing on it ;).
More like 54hp crank.. 29 years ago.. LOL! I think Burn-Your_Money dynoed a stock 1.6D a few years back.. it was struggling to push 35whp.. SCARY.
Reply #3April 04, 2013, 08:00:18 pm
Rising
  • 385
Re: Re: Deciding on parts for my turbo setup
« Reply #3 on: April 04, 2013, 08:00:18 pm »
Haha great ::) my thunderous 58hp was overly optimistic haha
Yeah I think its worth shooting for. But maybe I should just do it in stages. Like maybe bolt the Gasser manifold up. Then the turbo no intercooler just a down pipe. Then the exhaust. Then the inter cooler and then vane control?
Are eBay AN lines acceptable oil lines? Anyone know the vnt oil fitting thread? What about cheap charge piping? Junkyard?
Sent from my ThunderBolt using Tapatalk 2
Reply #4April 04, 2013, 09:20:22 pm
  • 2931
« Reply #4 on: April 04, 2013, 09:20:22 pm »
 I'd go with the VNT too.
 I'd arrainge the stages differently though.
 Turbo no intercooler first,
 then the exhaust, it's easier coming out of the turbo than with the stock downpipe
 because it's not so far to the driver's side that it needs a sharp turn back to the p-side to clear the shifter stuff and make it back to the tunnel.
 Comes out of the turbo, turns 90 and toward the tunnel.
 Which gasser intake? Which way does it point?
 The vanes can be tied to a spot in the middle and used that way for awhile with good results, there are some sweet spots that make driving fun but you will need to watch your boost gauge.
 If you got the oil supply fitting with the turbo; 5/16" brake line will work with the compression fitting.
If not, it's damn expensive at the dealership so I've always wonderd about the threads on the turbo side and a cheaper source for this fitting.
 A question mark shaped pipe will need to be fabricated to go between the turbo and intake.
« Last Edit: April 04, 2013, 09:21:58 pm by fatmobile »
Reply #5April 04, 2013, 11:02:06 pm
Blocksmith
  • 261
    Wrench Lurker
« Reply #5 on: April 04, 2013, 11:02:06 pm »
This is very much what I intend to do (return to, really) in the very near future; what I can say is that the turbo oil feed line threads in the CHRA itself are M10x, either 1.25 or 1.00, I honestly don't remember, but it's the same as the oil pressure sensors in the head or the oil filter flange (convenient, right?). And that the turbo-to-intake manifold pipe is going to be complex enough that you might as well go the extra mile and plumb in the intercooler right off the bat, if you're thinking of installing one anyway--I'm assuming that if you're playing with a vnt, you're going to want more than 12 psi  ;), which is to say you're going to feel the need for an intercooler pretty much right away. Honestly the most difficult part about a vnt swap onto our old motors is the vane control mechanism, which will take some doing. I think of this (http://www.vwdieselparts.com/forum/viewtopic.php?f=21&t=11042) as the seminal work on mechanically-controlled vnt turbos, but I'm sure you've already run across that in your research on the subject. I have my own ideas about how it could be done, but I have yet to verify the design in real life situations. I can't speak to any particular knowledge of a cheap source of charge piping, as I bought my kit on ebay for around $100; doesn't satisfy the inner desire for ultimate thrift, I know, but I saw no other suitable option at the time... Do you have access to any welding equipment? It always seems like the silicone connectors is where the price gouging occurs, so if the need for those could be reduced...
Green 83 Rabbit 4dr, 5 speed ACH trans swap, ported 1.6D mech lifter w/ vnt15, na pump w/ gov mod, gasser intake mani, 2.5" exhaust, bilstein sports and cut mk2 springs, ss brake lines, 14" vw bottlecaps
Reply #6April 05, 2013, 11:03:20 am
davidm2232
  • 6
« Reply #6 on: April 05, 2013, 11:03:20 am »
i just got a vnt 15 bolted on my 1.6d. after a lot of research on oil lines, here is what i used. i two adapters very simialr to this at my local speed shop: https://www.pegasusautoracing.com/productdetails.asp?RecID=4192 . i connected them with a 3ft lenght of braided stainless -4an line. for the drain, i used the stock vnt drain flange and cut off the stock braided line. i ran 3/8 (?) fuel line from there to a hose barb that screws into a 3/8 NPT bung welded into the oil pan. I have had quite the time pulling all that info together so i figured i would share it. I am doing intake and exhaust tubing tonight. i'll let you know how it goes.
Reply #7April 05, 2013, 04:19:27 pm
Rising
  • 385
« Reply #7 on: April 05, 2013, 04:19:27 pm »
I was planning on running just a downpipe for a spell, either piped into my existing exhaust or just vented underneath the car, and then upgrading to a full exhast whenever i get some more funds... is that feasible or foolish?
I'm not entirely sure which model it is off of. I don't know anything about gasser vws, but it points towards the drivers side and is a logstyle long runner intake. Seems like it would be more efficient than the stock td intake.
I definitely would go light on the boost and run my vanes either entirely open or slightly closed until I got a full vane mechanism functioning. I considered running it off of a boost can until i could make a mechanical setup, but i've heard that is fairly bad method of controlling so I think i'll just put it all together once i'm ready.
This is great info! I'm going to research a bit more on the return line side since i don't have the adapter for that side either. If I can come up with a definitive solution for avoiding the stealership prices, i'll definitely post it up. I'd love to hear more about your project so I can prepare for my own. Share and share alike :)
Yeah I think it may be worth while to just plumb the whole thing. I may investigate some junkyard sources of pipe until I can upgrade to an aluminum piping kit. Seems to me that volvo's have an abundance of charge piping that could probably be pieced together... and intercoolers to boot!
Libby's design is definitely going to be my starting point for vane control. The idea is fairly flawless. IF he made a kit I would hands down buy one, but as it is I don't think they will ever get produced... maybe he'll chime in on this thread some time and give me some hints  ;D
Reply #8April 05, 2013, 06:03:29 pm
« Reply #8 on: April 05, 2013, 06:03:29 pm »
I know I've mentioned this company enough times to give people the impression that I work there, but a friend of mine who makes a living doing custom work on cars swears that he owes his business to this place. Columbia River Mandrel Bends. Decently priced source of pre-bent pieces.
Reply #9April 05, 2013, 09:21:22 pm
Blocksmith
  • 261
    Wrench Lurker
« Reply #9 on: April 05, 2013, 09:21:22 pm »
Don't know if this will help you, but FWIW the oil return flanges on K03's are the same footprint as a vnt15 return flange. What sort of tooling do you have access to? I could send you measurements (or even a physical cardstock cutout; heck, maybe even an actual flange) for you to fab your own return line.
Reply #10April 06, 2013, 05:30:15 am
Rising
  • 385
« Reply #10 on: April 06, 2013, 05:30:15 am »
Yeah I forgot about them. Would their 16 Gauge aluminum piping be acceptable for hotside turbo piping or do I need to go with steel? Might be easier to just weld the steel together...
Well I have a pretty basic set of tools. I have access to your standard grinders and sawzalls. But no welders or cnc machines haha.
That being said, I may just have to find a stock oil line and hack it up. . . This is where I start to again lean towards selling/trading all this for a stock turbo set up.
Oil Lines: Custom
Intake Piping: Custom
Exhaust Piping: Custom
Intake Manifold Flange: Custom
Vane Control: Custom
It seems almost impossible to fab all this up without much downtime since this is my daily driver... ::)
Reply #11April 06, 2013, 09:22:02 pm
  • 2931
« Reply #11 on: April 06, 2013, 09:22:02 pm »
Yeah, if you don't have access to a welder, you might not have the technology for this build.
 Something else to collect for this build is the exhaust brackets for the old-school 2-into-1 NA downpipes.
 So the exhaust doesn't pry hard on the turbo.
 One of the benefits of the VNT setup is being able to use the cheap and better flowing gasser intake.
 One that points toward the passenger side is a better place to start if you don't want an intercooler.
 I used the ?question mark pipe from a starion conquest turbo setup, to go from the turbo to intake.
Reply #12April 11, 2013, 06:15:35 am
Rising
  • 385
« Reply #12 on: April 11, 2013, 06:15:35 am »
Yeah I am a bit afraid of that. But I think that I could most likely pay a small shop around here to do the downpipe for me, and find a non weldable solution for the intake piping... This has certainly given me alot to think about though. I'm going to continue sourcing parts and see how things go. If I decide I can't get it up and running I'll just sell it off and look for a stock setup. Otherwise I think the VNT is worth the additional trouble.
Reply #13April 11, 2013, 01:22:04 pm
Rock3tman
  • 113
    prev: 60typ2, 68pickup, 79rabbitD. now: 83jettaTD
« Reply #13 on: April 11, 2013, 01:22:04 pm »
For a downpipe from a VNT-15 in an A1 Jetta, I used a down pipe from a junkyard Saab ( year/model?) de-flanged, cut & rotated that fits quite well between turbo outlet , short shift linkage, and where stock exhaust is routed; it is 2.25" stainless and has a flex section as well.  Its welded to a VNT-15 flange from tectonics tuning.
Reply #14April 11, 2013, 08:59:45 pm
Rising
  • 385
Re: Re: Re: Deciding on parts for my turbo setup
« Reply #14 on: April 11, 2013, 08:59:45 pm »
Ohh that's actually quite excellent information. My mk1 rabbit should be able to do something similar. Idk why I never thought of junkyard exhaust!
 Can you clue me in on an approximate age of the Saab? I wouldn't mind digging through a bunch of Saab's until I found one that looked right.
