Author Topic: Steering rack lubrication..........What to use?  (Read 10052 times)
March 30, 2013, 11:58:06 am
somolovitch3
  • 290
« on: March 30, 2013, 11:58:06 am »
Am rebuilding the Caddy's Steering Rack.....By the way thanks all for the info on the outer Right Bushing..
What should I use to re-grease it? I want something supper tacky and with a wide temp range. Had to steam clean the rack to get rid of all the little bits of crap the got in there due to falure of both boots.
Once again, thank you for your time and effert.
Byte Me, Gently
81 Caddy (Trk)
84 Gti (DumBunny)
Reply #1March 30, 2013, 12:04:48 pm
bbob203
  • 1789
Re: Steering rack lubrication..........What to use?
« Reply #1 on: March 30, 2013, 12:04:48 pm »
VW cv axle grease.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #2March 30, 2013, 07:22:22 pm
« Reply #2 on: March 30, 2013, 07:22:22 pm »
i use wheel; bearing grease... imo cv grease too light for that...
Reply #3March 30, 2013, 07:26:16 pm
« Reply #3 on: March 30, 2013, 07:26:16 pm »
I just use this stuff.
Reply #4March 30, 2013, 08:14:09 pm
wolf_walker
  • 1205
Re: Re: Steering rack lubrication..........What to use?
« Reply #4 on: March 30, 2013, 08:14:09 pm »
Cv grease has worked well for me a couple times. Remember the pass side inner bushing.
Sent from my SCH-I535 using Tapatalk 2
Mentat Text Two
Reply #5March 30, 2013, 09:50:05 pm
  • 2926
« Reply #5 on: March 30, 2013, 09:50:05 pm »
I use dry moly spray.
Hagar suggested it.
Reply #6March 31, 2013, 11:48:38 am
wolf_walker
  • 1205
« Reply #6 on: March 31, 2013, 11:48:38 am »
I think the Bently lists a specific moly lube too.
Mentat Text Two
Reply #7March 31, 2013, 01:45:09 pm
somolovitch3
  • 290
« Reply #7 on: March 31, 2013, 01:45:09 pm »
I have been looking for a while now.
CV, and other "General Purpose/Wheel Bearing" type grease is not "Tacky" enough.
The original grease was very "sticky". I am trying to replace that.
Worth hhs 2000 looks good, if I could find it locally. Or a high pressure chain grease might be okay.
What brand of dry Molly are we talking?
Again thank you for your time and effert.
Byte Me, Gently
81 Caddy (Trk)
84 Gti (DumBunny)
Reply #8March 31, 2013, 04:51:01 pm
« Reply #8 on: March 31, 2013, 04:51:01 pm »
A marine grade teflon based lubricant will work, it is designed to be submerged with the stern drives lower unit.. its never coming off.
Reply #9March 31, 2013, 06:25:14 pm
bbob203
  • 1789
« Reply #9 on: March 31, 2013, 06:25:14 pm »
this thread got so over involved. Cv axle grease is so incredibly slick and sticky I used it on my shifter parts and works awesome and it doesn't get washed off in the rain.
03 Jetta wagon TDi
Reply #10March 31, 2013, 06:32:16 pm
« Reply #10 on: March 31, 2013, 06:32:16 pm »
I think you're sweating the small stuff. Volkswagen is not NASA. They weren't looking for a grease that would make it around the sun and back. Volkswagen sold economy cars, so their criteria was only that it be cheap yet last the length of the warranty period of the car. That's it. The steering gear isn't under a lot of load and it doesn't get very hot, so as long as you put a good grease in it, and keep water and dirt out, it will last a very long time.
Anyway, I think it's actually the "SynPower" Valvoline that I use, it's red and pretty tacky. There's also this stuff, which is, red and tacky like it says, but I don't think it's worth the price and it's hard to find.
Reply #11April 04, 2013, 09:37:23 pm
  • 2926
« Reply #11 on: April 04, 2013, 09:37:23 pm »
I think it's CRC dry Moly.
 A green can.
Reply #12April 16, 2013, 03:12:22 am
somolovitch3
  • 290
« Reply #12 on: April 16, 2013, 03:12:22 am »
Grainger carrys the CRC Dry Molly locally, and I am going to try a Marine Products Spline and Bushing Grease. It is a pretty blue and as for tacky, can you say "glue"?It is also High/Low Temp, and Extreame Pressure.
I will let you all knowl how it turns out.
Once again thank you for your time and effert.
Byte Me, Gently
81 Caddy (Trk)
84 Gti (DumBunny)
