Author Topic: MHI TD04-18T turbo--Compressor map plots and turbo calculations  (Read 20740 times)
March 29, 2013, 07:52:14 pm
0 Xero 0
Hey, everyone, this is my first post here. I hope to acquire a vw caddy or rabbit in the near future and I've already researched and read a lot of threads and info on modifying these engines. I've gone to great lengths to plan out (what I hope will be) my future build. I'd like anywhere from 150-200 whp. I've done a lot of research into which turbo will work best for my application. I've plotted out where the engine would make peak horsepower and I've calculated that at 30 PSIG, I'll be at roughly 76 percent compressor efficiency with a pressure ratio of 2.7. That is as good as you can get as far as I'm concerned. Ideally the combustion events will be on the leaner side so that smoke (wasted fuel) and EGTs are minimal. Here is a site that has the map for this turbo and many other turbos I think a lot of you would find useful.
http://www.stealth316.com/2-3s-compflowmaps.htm
Here is the site that has the measurements for the wheels and housings.
http://www.stealth316.com/2-turboguide.htm
 I've checked this map against many Garrett and IHI turbos, but the MHIs come out on top. The closest turbos I've found to this one are the TD04-16T and TD05-14G. The main differences between these are the compressor wheels, but the TD05 has a bigger turbine too. Oddly enough, the TD04-18T still outflows both turbos in most regards. I don't know if the two percent will make a huge difference in overall engine efficiency or if it would be better to get the TD04-16T for better spool-up times.
Have any of you run any MHI turbos with any marked success?
« Last Edit: March 31, 2013, 09:48:48 am by 0 Xero 0 »
Reply #1March 29, 2013, 10:09:57 pm
mystery3
  • 774
Re: MHI TD04-18T turbo
« Reply #1 on: March 29, 2013, 10:09:57 pm »
I take it you want to do custom manifolds and downpipes? I haven't heard of anyone using mitsu turbos but I think it's probably because of the flange incompatibility more than anything, too much work for a junkyard turbo.
Reply #2March 30, 2013, 09:44:47 am
0 Xero 0
« Reply #2 on: March 30, 2013, 09:44:47 am »
I don't mind fabricating the exhaust system. I want a 2.5" exhaust anyways. The other MHI turbos that are closest in efficiency are 74 percent efficient. That's awesome too and is stilling better than any others I've looked at. I want the engine to perform optimally and run a little lean with an AFR of 20:1 if possible and these turbos will allow that.
Reply #3March 30, 2013, 09:48:57 am
wolf_walker
  • 1205
« Reply #3 on: March 30, 2013, 09:48:57 am »
Don't the Volvo guys run those?  The numbers sound familiar.
Not sure how apples to oranges it might be, but they may be able to offer some
hands on experience with them.  turbobricks forum is good
Mentat Text Two
Reply #4March 30, 2013, 10:19:10 am
0 Xero 0
« Reply #4 on: March 30, 2013, 10:19:10 am »
Yeah, guys use em on volvos and saabs frequently. The problem is gas engines rarely run a pressure ratio over 2.0 and their experiences wouldn't correlate well to a diesel application. Hasn't anybody tried to make an adaptor for the exhaust flange for these so the stocks manifold would work? I'll probably try that first assuming I get a caddy soon.
Reply #5March 30, 2013, 10:40:33 am
0 Xero 0
« Reply #5 on: March 30, 2013, 10:40:33 am »
Reply #6March 30, 2013, 11:12:26 am
« Reply #6 on: March 30, 2013, 11:12:26 am »
Rabbit Jockey could chime in if he is interested on the map portion.
The adapter could be done like that or you could use a flange fitting the VW manifold welded to pipe welded to a flange matching your turbo. Then it could be clocked and turned however you wanted. If you wanted.
Reply #7March 30, 2013, 02:33:41 pm
0 Xero 0
MHI TD04-18T turbo
« Reply #7 on: March 30, 2013, 02:33:41 pm »
Yeah, I like the direct flange adapter idea personally. It's simpler. I'd also like to use a diverter valve like the one BD diesel makes for light duty trucks. Has anyone done that on these engines?
Reply #8March 31, 2013, 09:48:12 am
0 Xero 0
« Reply #8 on: March 31, 2013, 09:48:12 am »
Here's my plot on the compressor map. I'm sure it's slightly off because I had to guess a little for my boost (and P/R by extension) at the lower end of the map, so that is probably wrong, but I think most of it is correct. The parameters I'm going by are these:
  • Max Boost - 30
  • Atmospheric Pressure - 11.47 PSI or 23.35 in Hg
  • VE - 90% (this may be off; however, this seems like a feasible number with a ported head and exhaust manifold)
  • Compressor Efficiency - 76% (in this case)
  • BSFC - 0.409 @ 20:1 AFR; 0.372 @ 22:1 AFR (again, I'm making an assumption based on what I've read)
The main differences between the MHI turbos are wheel sizes and housing sizes. The TD04s have 6 cm^2 turbine housings or 0.41 A/R and the letters after the frame size (04, 05, 06, etc.) correspond to the turbine wheel. I'm assuming my turbo has the TD04L 76 trim (41 mm/47 mm) or TD04H 73 trim (44 mm/52 mm) turbine. The number after the frame size (15G, 16T, 18T, etc.) designates the compressor wheel size and the letter is the wheel style. For the 18T, the measurements are 45 mm/56 mm and the T means the blades are all the same height. A G-style wheel has half of the blades shorter than the rest.
I'm sure some of you are better at this than me, so if I made any mistakes, feel free to correct me. I used Garrett's equations for a lot of this and tinkered with some turbo calculators I felt were decent for a diesel.
Reply #9April 01, 2013, 04:59:27 am
« Reply #9 on: April 01, 2013, 04:59:27 am »
  • Max Boost - 30
yes but 30 psi would be nearly 3bar on the map
i think you just mis typed this?  should be 14.7psi
I usually use 85 when considering a ported head, but that is very optimistic
i usually use a bsfc of .36-.38 and afr of 18:1 but they are all guesses, i just base all my numbers off of comparing dynos to the engine specs of the car.
[/list]
Reply #10April 01, 2013, 05:01:52 am
Reply #11April 01, 2013, 06:24:47 am
0 Xero 0
Re: MHI TD04-18T turbo--Compressor map plots and turbo calculations
« Reply #11 on: April 01, 2013, 06:24:47 am »
I used a P/R of 2.7 and an atmospheric pressure of 11.47 because the elevation is 6800 feet where I live. I'll re-run my data, but I don't like the squirrel performance calculator. Most calculators are catered toward gas engines that run around 10-12:1 within P/Rs.
Reply #12April 01, 2013, 06:48:17 am
« Reply #12 on: April 01, 2013, 06:48:17 am »
If there was only a spot in your profile to put your location...oh wait there is.
That kind of thing helps others. In this case Trev could have at least had a clue that you were no where near sea level.
Reply #13April 01, 2013, 09:03:12 am
« Reply #13 on: April 01, 2013, 09:03:12 am »
I don't really see anything on the Squirrel calculator that is in any way catered to the fuel type of the engine, other than the default AFR / BSFC numbers that are on there?  Just curious what you don't like about it.
Reply #14April 01, 2013, 09:56:48 am
« Reply #14 on: April 01, 2013, 09:56:48 am »
ok i understand, that makes a big difference. also the numbers on the y axis are not a definite pressure, they are a ratio so at 11.47 psi atmospheric pressure and 30 psi of boost, it would put you around 3.6 on the y axis.  i hope that helps
