Author Topic: Will this kerma feed line for k03/k04 work with k14?  (Read 3637 times)
March 28, 2013, 09:45:44 am
bbob203
  • 1789
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #1March 28, 2013, 04:54:05 pm
rbremiller
  • 69
Re: Will this kerma feed line for k03/k04 work with k14?
« Reply #1 on: March 28, 2013, 04:54:05 pm »
That looks like it will fit. I used this line for my K14 MTDI set-up.http://compare.ebay.com/like/271167354141?var=lv&ltyp=AllFixedPriceItemTypes&var=sbar It's shipped right from China; takes 3-4 days tops. Sincerely. It is of good quality. I first tried to make one out of Earl's fittings but it looked cobbed. I'll use one on my MKIV Jetta when it needs one. Same part fits both because it's flexible. You can't go wrong with Kerma's though; it's more pricey but eliminates the banjo fitting. My 2¢.
'91 180k Audi 80Q mTDI DD AHU, K14, LT pump,
http://www.motorgeek.com/viewtopic.php?t=45645
'99 Jetta TDI 204k '02 engine, RC3+E, 11mm IP, .216, Racepipe, 2.5''SS exhaust, PD Lift pump,  Boostvalve, PanzerPlate, boost gauge, MAF delete.
'89 Audi 80Q ...waiting
'85 BMW R80
Reply #2March 28, 2013, 04:56:59 pm
bbob203
  • 1789
« Reply #2 on: March 28, 2013, 04:56:59 pm »
Thank you sir!!  ;D
03 Jetta wagon TDi
