Author Topic: Pre chambers,,  (Read 3322 times)
March 26, 2013, 12:38:23 pm
TUFFY
  • 104
Pre chambers,,
« on: March 26, 2013, 12:38:23 pm »
Hello, Is there any difference in factory turbo pre chambers compared to the NA pre chambers? I am not sure what most of you guys call them lol.
Reply #1March 26, 2013, 02:08:30 pm
Re: Pre chambers,,
« Reply #1 on: March 26, 2013, 02:08:30 pm »
Yes, they are a different size.
Reply #2March 26, 2013, 02:24:06 pm
TUFFY
  • 104
Re: Pre chambers,,
« Reply #2 on: March 26, 2013, 02:24:06 pm »
Can turbo ones be installed in a NA head?
Reply #3March 26, 2013, 02:26:53 pm
Re: Pre chambers,,
« Reply #3 on: March 26, 2013, 02:26:53 pm »
If memory serves, the TD ones are slightly smaller in diameter than the NA ones and so, no, they will not work in an n/a head.  The n/a ones could be installed in a TD head if it is machined to fit them.  I could have that backwards, tho.
Reply #4March 26, 2013, 02:28:00 pm
Re: Pre chambers,,
« Reply #4 on: March 26, 2013, 02:28:00 pm »
no. The 1.5L and 1.6 TD are 30mm across the face. The N/A prechambers are 32mm across the face. Being a press fit there is no way to install them easily.
Edit: libby was in there the same time I was. Carry on.
Reply #5March 26, 2013, 03:52:28 pm
TUFFY
  • 104
Re: Pre chambers,,
« Reply #5 on: March 26, 2013, 03:52:28 pm »
OK, I am stuck with NA ones then. Would there be much power difference on a high boost lots of fuel 1.6 between the turbo and NA chambers?
Reply #6March 26, 2013, 05:31:05 pm
Re: Pre chambers,,
« Reply #6 on: March 26, 2013, 05:31:05 pm »
No.  There wouldn't be any difference at all.
Reply #7March 26, 2013, 07:01:22 pm
Re: Pre chambers,,
« Reply #7 on: March 26, 2013, 07:01:22 pm »
Reply #8March 26, 2013, 08:05:15 pm
srgtlord
  • 797
Re: Pre chambers,,
« Reply #8 on: March 26, 2013, 08:05:15 pm »
HAHAHAHAHAHHAAHHAHAHHAHAHAHAHAHAHAHHAAHHA
