Author Topic: Deleting Manifold Blow off Valve?  (Read 8616 times)
Reply #15March 20, 2013, 02:14:30 pm
Re: Deleting Manifold Blow off Valve?
« Reply #15 on: March 20, 2013, 02:14:30 pm »
well, i had been using a gasser intake before that, to delete the overboost valve..
before that, i was running a wine cork.. the wine cork will hold enough pressure to blow your block apart..
the dual plenum is my favorite way to delete the overboost valve..
Reply #16March 20, 2013, 07:13:15 pm
shwak23
  • 417
    • Blackdog Junkyard
Re: Re: Deleting Manifold Blow off Valve?
« Reply #16 on: March 20, 2013, 07:13:15 pm »
If you take a vw center cap. One of the small plastic ones. And you dremel off the retaining clips it will fit perfectly where the blowoff valve was. You must use the original v-band style clip. I don't have a picture. But trust me it works. Actually. I do have a picture give me a minute.
Ok
My only regret was not having a center cap in nicer shape.
Sent from Outer Space!
Reply #17March 20, 2013, 11:31:50 pm
« Reply #17 on: March 20, 2013, 11:31:50 pm »
that wont seal unless you put silicone between it and the mani..
Reply #18March 21, 2013, 06:54:27 am
« Reply #18 on: March 21, 2013, 06:54:27 am »
Clearly it works, trust him lol.
Reply #19March 21, 2013, 03:12:16 pm
« Reply #19 on: March 21, 2013, 03:12:16 pm »
lol...
Reply #20March 21, 2013, 10:22:22 pm
shwak23
  • 417
    • Blackdog Junkyard
Re: Re: Re: Deleting Manifold Blow off Valve?
« Reply #20 on: March 21, 2013, 10:22:22 pm »
I have driven it like this for a while. Seems to work.... Wouldn't I notice if it was leaking?
