Author Topic: Head gasket problem  (Read 3531 times)
March 19, 2013, 12:09:24 am
Zukiman87
  • 65
Head gasket problem
« on: March 19, 2013, 12:09:24 am »
Having a hard time finding the right head gasket for my block. It's a 1.6 TD. none of the gaskets I've got match up tho. The coolant holes are blocked off on one side. Any suggestions to whet to get the fright gasket? Or will the VR steel one solve my problem?
Reply #1March 19, 2013, 01:31:27 am
Re: Head gasket problem
« Reply #1 on: March 19, 2013, 01:31:27 am »
A lot of them come that way.  I drilled the 'missing' holes on some, and didn't notice any difference.
Reply #2March 19, 2013, 04:34:12 am
« Reply #2 on: March 19, 2013, 04:34:12 am »
you have a hydro setup. You could use the aaz HG, but don't think about using a VR gasket, not even close.
Reply #3March 19, 2013, 07:29:02 am
« Reply #3 on: March 19, 2013, 07:29:02 am »
VR = Victor Reinz
You can use the AAZ metal gasket, but unless your siht is straight it will never seal.
Reply #4March 19, 2013, 11:57:23 am
wolf_walker
  • 1205
« Reply #4 on: March 19, 2013, 11:57:23 am »
I've used that steel AAZ gasket on two high miler 1.6's in the past, no machine work done, didn't leak.
I used that spray copper headgasket dressing and wouldn't use them without it.  I'm not a fan
of magic goo, but a shop owner friend that does a ton of euro car HG's uses it on everything and
has never had one leak, so I gave it a shot.
Take that fwiw, I didn't have much to loose and one of them I drove myself for 40 or 50K.
Mentat Text Two
Reply #5March 19, 2013, 12:33:56 pm
Zukiman87
  • 65
« Reply #5 on: March 19, 2013, 12:33:56 pm »
FYI this is the block for my 1.5/1.6 hybrid. Minty block minty 1.5 head. I'm going to plug the second oil return hole. I've found the right gasket from Lordco. But since the clearances will be different I'm thinking i may just get the three notch just to be safe. You think it will affect the performance much between the 1 notch and three notch with this build?
Reply #6March 19, 2013, 02:23:20 pm
« Reply #6 on: March 19, 2013, 02:23:20 pm »
Why does one not measure piston protrusion properly and make the right purchase here?
Reply #7March 19, 2013, 02:34:14 pm
« Reply #7 on: March 19, 2013, 02:34:14 pm »
running the 1.5, or 1.6 gasket?
the 1.5 gasket comes in 5 sizes..
the 1.6 gasket comes in 3 sizes..
Reply #8March 19, 2013, 03:52:42 pm
Zukiman87
  • 65
« Reply #8 on: March 19, 2013, 03:52:42 pm »
Got it figured out lol. Right head gasket otw. Brain has went to mush on my build. It got sidelined last summer. Bought a new house and have been doing renown so my engine and parts have been in boxes since then lol. Time to get it put together and running!
Reply #9March 19, 2013, 08:16:15 pm
  • 2931
« Reply #9 on: March 19, 2013, 08:16:15 pm »
delete
