S-PAutomotive.com
Author Topic: Turbo Diesel in VA!!  (Read 6741 times)
Reply #15March 03, 2013, 03:53:04 pm
camboscams
  • 324
Re: Turbo Diesel in VA!!
« Reply #15 on: March 03, 2013, 03:53:04 pm »
This is a 12mm engine correct?
81' White 1.6l Rabbit 4dr Holseted
72' Ford F-250 390cid
2014 JSW 2.0L TDI Stg 2, CP3 HPFP
Reply #16March 03, 2013, 06:54:34 pm
Jagerauto
  • 144
« Reply #16 on: March 03, 2013, 06:54:34 pm »
Based on it being a Turbo Diesel then yes it should be, I will pull valve cover to verify.
Reply #17March 03, 2013, 09:04:05 pm
DRP67207
  • 50
« Reply #17 on: March 03, 2013, 09:04:05 pm »
Interested, PM sent.
Reply #18March 03, 2013, 10:40:07 pm
Jagerauto
  • 144
« Reply #18 on: March 03, 2013, 10:40:07 pm »
Well I can't get it I turn over with a starter.
Anyways.. I guess that means I can't get a good compression test on it. So off with the head to inspect. Then I can flip her over and inspect the case/rods.
Keep posted!
Reply #19March 04, 2013, 05:44:17 pm
Jagerauto
  • 144
« Reply #19 on: March 04, 2013, 05:44:17 pm »
Well I pulled head... No crack anywhere in the head!!! Cylinders look great! Bottom end spins very well.
I took plenty of pics (kinda dirty but judging by the clean parts, it will clean up nicely)
I took pics of it before I cleaned it, so you guys don't think I cleaned it to cover anything up ;)
After some intense bristle disc action.
The block
Reply #20March 04, 2013, 07:19:57 pm
RustyCaddy
  • 387
« Reply #20 on: March 04, 2013, 07:19:57 pm »
What is the part number on the head?.
Are there any kind of a stamp on the precups (they might have been smoothed off)?
Reply #21March 04, 2013, 08:35:49 pm
« Reply #21 on: March 04, 2013, 08:35:49 pm »
That thing looks low miles inside! :P
Reply #22March 04, 2013, 10:43:46 pm
Jagerauto
  • 144
« Reply #22 on: March 04, 2013, 10:43:46 pm »
I am confident that the 109k on the odo is correct. $400 is a steal. Sounds like Cambo is getting this one.
Reply #23March 05, 2013, 09:37:20 am
« Reply #23 on: March 05, 2013, 09:37:20 am »
It looks like a small crack on the right side of that pre-cup opening.  I would also feel concerned about the abrading technique.
Reply #24March 05, 2013, 11:10:54 am
Jagerauto
  • 144
« Reply #24 on: March 05, 2013, 11:10:54 am »
What technique? I your talking of how I cleaned it... I used a bristle disc. It is a hard rubber an did not remove any metal. Trust me I'm not stupid enough to take a grinding wheel or wire wheel to it. Haha.
I'll get a better pic of that precup I'm pretty sure it's not a crack.
I will be delivering this to camboscams later this week so lets say "PENDING SALE" ;)
Reply #25March 05, 2013, 12:07:42 pm
Jagerauto
  • 144
« Reply #25 on: March 05, 2013, 12:07:42 pm »
I do have this that would go awesome as a spare!
Reply #26March 05, 2013, 02:02:06 pm
« Reply #26 on: March 05, 2013, 02:02:06 pm »
The green 3M bristle brushes definitely will remove aluminum and to a lesser extent will remove steel as well.
What looks like a small crack in that pic may just be an abrasion mark.
Reply #27March 05, 2013, 05:50:15 pm
Jagerauto
  • 144
« Reply #27 on: March 05, 2013, 05:50:15 pm »
I'm sure if you sit there and hit the same spot it would.. But I've used it plenty of times. No problems. I hit it long enough to take the nastiness off and that's it.
Reply #28March 05, 2013, 07:41:35 pm
camboscams
  • 324
« Reply #28 on: March 05, 2013, 07:41:35 pm »
Lucky for me i have unlimited access to a surface grinder at work, so surface scratches are not a problem.
As for the crack in the pre-cup has there ever been any cases of that causing any problems?
Reply #29March 05, 2013, 07:52:03 pm
« Reply #29 on: March 05, 2013, 07:52:03 pm »
Yes, any cracks in the precup are a big problem - probably the biggest problem faced with the IDI engines.  They can grow very quickly and once the prechamber is cracked through it will hammer into the piston destroying both the piston and head.  Sometimes the pieces will fall into the cylinder destroying the rod and block as well.
« Last Edit: March 05, 2013, 07:54:09 pm by libbydiesel »
