Author Topic: Time to start assembling 1.5 TD / 1.9L Franken Diesel.  (Read 109490 times)
Reply #120March 13, 2013, 07:55:11 am
Alcaid
  • 549
Re: Time to start assembling 1.5 TD / 1.9L Franken Diesel.
« Reply #120 on: March 13, 2013, 07:55:11 am »
If you are at the point of more fuel than air, then add more air :p
Regarding the girdle: http://www.vwdiesel.net/forum/index.php?topic=27133.0
'10 VW Passat 1.6TDI Highline
Reply #121March 13, 2013, 09:22:57 pm
JamesT
  • 151
« Reply #121 on: March 13, 2013, 09:22:57 pm »
I would say somewhere around 16cc per cylinder would hydrolock.  Of course that would be theoretical.  There would have to be some room for air.
93 Golf - AAZ with some fueling
78 Rabbit - 1.5 DIESEL (finally)
[(+)===o===(+)]
 (++\==o==/++)
Reply #122March 14, 2013, 07:00:07 pm
« Reply #122 on: March 14, 2013, 07:00:07 pm »
the pump is rated @ 90cc/min i believe.. not 90cc/stroke..
think of it, the pump plunger would need to be the size of a honda 90 piston to put out 90cc/stroke!
Reply #123March 14, 2013, 07:53:50 pm
Jetmugg
  • 530
« Reply #123 on: March 14, 2013, 07:53:50 pm »
That's good thinking right there.  I got a little carried away. :o
Steve.
Reply #124March 14, 2013, 11:47:36 pm
Alcaid
  • 549
« Reply #124 on: March 14, 2013, 11:47:36 pm »
Actually pumps are rated in cc / 1000 strokes
Reply #125March 15, 2013, 05:47:18 am
Jetmugg
  • 530
« Reply #125 on: March 15, 2013, 05:47:18 am »
That's even better thinking.
Reply #126March 15, 2013, 12:20:52 pm
« Reply #126 on: March 15, 2013, 12:20:52 pm »
thank you.. wasnt sure if it was a timed reading like gasser fuel injector flow, or something else..
90cc/stroke sounded out of the question..
90cc/min sounded more plausible..
but 90cc/1000strokes, that makes ALOT more sense..
Reply #127March 28, 2013, 08:11:04 am
« Reply #127 on: March 28, 2013, 08:11:04 am »
looks like just what you need, although they are really really light.
http://forums.vwvortex.com/showthread.php?5998497-BFI-020-Clutch-Kits-amp-Billet-Flywheels
Reply #128March 28, 2013, 12:55:09 pm
Jetmugg
  • 530
« Reply #128 on: March 28, 2013, 12:55:09 pm »
I will probably end up with one of the BFI flywheels.  I already have a 210mm pressure plate & clutch setup.
Steve.
Reply #129March 28, 2013, 04:03:23 pm
« Reply #129 on: March 28, 2013, 04:03:23 pm »
i had no idea they had those billet wheels, im thinking they just now came out?
Reply #130July 27, 2013, 09:21:50 am
« Reply #130 on: July 27, 2013, 09:21:50 am »
Where are you at with this mr jetmugg
Reply #131August 01, 2013, 12:27:55 pm
Jetmugg
  • 530
« Reply #131 on: August 01, 2013, 12:27:55 pm »
World Of Speed is Sept 7-10.  I am working on this deal every day.  It WILL be done, and will run at World of Speed, I just don't have a lot of time to spare between now and then.
Engine and trans are in the truck.  Yesterday, I got the throttle linkage and clutch cable worked out and adjusted.  Tonight I will fab up the radiator mounts.  Intercooler is mounted and plumbed.  The 2" tubing shown in the photo was replaced by 2.5" tubing over the last week.
There's still plenty to do, but it's within sight.
Reply #132August 01, 2013, 12:31:40 pm
Jetmugg
  • 530
« Reply #132 on: August 01, 2013, 12:31:40 pm »
A few more pics - need to upload more...
Reply #133August 01, 2013, 02:19:23 pm
carrizog60
  • 978
« Reply #133 on: August 01, 2013, 02:19:23 pm »
i think 0.95 wouldnt be enough advance...
Portugal
Reply #134August 01, 2013, 06:35:47 pm
« Reply #134 on: August 01, 2013, 06:35:47 pm »
On a performance pump like mine and his .95 maybe too much for the high rpm, but not too too much that it is horribly bad. Giles told me between .90 and .95, his pump builder probably did the same. The only thing I would do different is take that red line at 5500 rpm and move it to 6,000 :D
« Last Edit: August 01, 2013, 06:52:30 pm by theman53 »
