Author Topic: Injector Pump out of spec should i even run it?  (Read 21202 times)
February 21, 2013, 08:50:33 pm
vw-tim
  • 160
« on: February 21, 2013, 08:50:33 pm »
So the injector pump is out of spec. Its worn out and i have to set it at 1.28mm to get it to run and idle good. Im havent driven it at all but would this cause any issues with the engine? Should i just look at getting a rebuild injector pump or saving some money and buying another used injector pump that is still in good spec? Its a 1.5L injector pump. It doesn't leak at all but im just wondering is it bad to use i understand i wont get as good of mpg or as good of power but i dont think im ready to just spend $500 on a rebuild pump. looking for feedback thank you!
Reply #1February 21, 2013, 09:21:03 pm
Re: Injector Pump out of spec should i even run it?
« Reply #1 on: February 21, 2013, 09:21:03 pm »
Could be your injectors are out of spec...
Reply #2February 21, 2013, 09:37:33 pm
vw-tim
  • 160
« Reply #2 on: February 21, 2013, 09:37:33 pm »
how can the injectors be out of spec? Just worn out parts on the inside?
Reply #3February 21, 2013, 09:49:57 pm
« Reply #3 on: February 21, 2013, 09:49:57 pm »
You got it Pontiac, as they wear it takes more advance to make them pop at the right time.
Reply #4February 21, 2013, 10:42:43 pm
vw-tim
  • 160
« Reply #4 on: February 21, 2013, 10:42:43 pm »
interesting how can i tell if the injector is good or bad then? and also what is the best way about repairing them would i have to rebuild the whole injector? or just the spring on the inside?
Reply #5February 21, 2013, 11:26:57 pm
mystery3
  • 774
« Reply #5 on: February 21, 2013, 11:26:57 pm »
There's a how-to thread around here somewhere on building your own pop tester to check the opening pressure and spray pattern and such.
Reply #6February 22, 2013, 03:37:30 am
homerj1
  • 433
« Reply #6 on: February 22, 2013, 03:37:30 am »
http://members.shaw.ca/vwdiesel/DIY_Inj_Tester/DIY_Injector_Tester.html
Reply #7February 22, 2013, 05:59:31 am
« Reply #7 on: February 22, 2013, 05:59:31 am »
Lotta variations on the theme... google image-search "injector pop tester".
Here's one:
The reservoir is bigger than needed, but it was in the shop, lol,  I'll probably change it for a craft-store glue bottle.
Reply #8February 22, 2013, 08:42:01 am
« Reply #8 on: February 22, 2013, 08:42:01 am »
...or even better, make the injectors spray in to the reservoir.... :)
Reply #9February 22, 2013, 08:44:39 am
vw-tim
  • 160
« Reply #9 on: February 22, 2013, 08:44:39 am »
is there a way to make a pop tester with out having to weld on a piece? I guess ill hit up my local vw shop and see if they can pop test them for me
Reply #10February 22, 2013, 09:02:18 am
« Reply #10 on: February 22, 2013, 09:02:18 am »
IIRC, the folks using a "porta-power" type of hydraulic tool usually don't have to weld fittings, they might be obtained cheap on Craigslist or the hot-tool stores... er, I mean pawn-shops, etc.
The bottle-jack is cheap, but often needs a fitting added.
I braze stuff like this more often then weld. Easier and less chance of damaging the goods.
I was planning on putting the injector high enough to spray into the rez, but took the lazy route. Maybe I'll do that if I upgrade.
Reply #11February 22, 2013, 09:28:13 am
vw-tim
  • 160
« Reply #11 on: February 22, 2013, 09:28:13 am »
hmm i guess ill be on the look out for a porta power jack like that i harbor freight has this..
http://www.harborfreight.com/4-ton-heavy-duty-portable-hydraulic-equipment-kit-44899.html
also found this the price is a lot better!
http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?productId=100616382&storeId=10051&langId=-1&catalogId=10053&MERCH=REC-_-product-2-_-100595209-_-100616382-_-N#.USerD6XCaSo
« Last Edit: February 22, 2013, 09:31:06 am by vw-tim »
Reply #12February 22, 2013, 09:49:26 am
92EcoDiesel Jetta
« Reply #12 on: February 22, 2013, 09:49:26 am »
And dump dirty fluid into the injectors? ???
Reply #13February 22, 2013, 10:27:53 am
homerj1
  • 433
« Reply #13 on: February 22, 2013, 10:27:53 am »
Yea, good pt.  Dirty = Bad
I sort of digress, but,
When buying a used diesel vehicle, I always ( after about 1000 to 2000 km of driving) cleaning the nozzles with Diesel Purge in a closed loop manner. ( looped the diesel fuel return hose from the IP back into the Diesel Purge can)
I always find it makes a big difference with: throttle response, performance and economy and engine noise.
But, I did find that new injector nozzles on my AHU made a big diff. That was without calibration - just a nozzle size increase from stock to .205 Veg. nozzles
I never really thought that injector size and cleanliness on a diesel (except for the extremes - too dirty or too big - "that's what she said" ) was that super important.
 But it clearly is.
« Last Edit: February 22, 2013, 10:31:56 am by homerj1 »
Reply #14February 22, 2013, 11:05:57 am
« Reply #14 on: February 22, 2013, 11:05:57 am »
Nah, inline filter between the rez and the pump.
Good idea to circulate the fluid a few times through the system without an injector in place, to flush the crud out before testing.
