Author Topic: TDI VE what about exhaust manifold which is the best  (Read 14638 times)
February 17, 2013, 10:00:32 am
jabcok20
  • 15
    1.7 m-tdi vnt20 electronic map sensor
« on: February 17, 2013, 10:00:32 am »
Hello i search info for the best exhaust manifold for my tdi afn. By few days i want to put gtb1756vk turbo. So for 220HP is it worth to change ori manifold from b5 AWX to other better manifold. I saw that people put in this from old diesel ( with few changes ) or from 1.6td. Is it worth to put one of those?
Or waht about manifoldfrom vw sharan tdi
Uploaded with ImageShack.us
Reply #1February 18, 2013, 05:03:05 am
G60ING
  • 170
    Corrado TDI
    • My VW Projects
Re: TDI VE what about exhaust manifold which is the best
« Reply #1 on: February 18, 2013, 05:03:05 am »
I've thought about a Sharon manifold but with the location of the turbo changing you would need new oil lines, turbo inlet piping and downpipe.
Reply #2February 23, 2013, 12:23:08 am
Henk
  • 111
« Reply #2 on: February 23, 2013, 12:23:08 am »
interesting flowing on that, looks better than standard.
I just have a normal manifold with the 4 bolt fitting at 45degrees to the head, i'm sure it'll be good enough for both our needs, plus would you be able to fit that manifold in d'you think?
Mid Engine
Berg Cup
M-TDi
Caddy!
Reply #3March 01, 2013, 12:22:05 pm
« Reply #3 on: March 01, 2013, 12:22:05 pm »
this is what i did for a high-flow manifold..
turbo header!!
StreetToys 2000 builds them.. this is one of his old "space saver" manifolds, they are not produced like this any longer.
they are expensive, but they are awesome as well..
Reply #4March 01, 2013, 05:55:24 pm
G60ING
  • 170
    Corrado TDI
    • My VW Projects
« Reply #4 on: March 01, 2013, 05:55:24 pm »
Good point my b5 manifold barely fits in my my corrado
Reply #5March 01, 2013, 07:02:04 pm
Re: Re: TDI VE what about exhaust manifold which is the best
« Reply #5 on: March 01, 2013, 07:02:04 pm »
I'm eagerly watching this thread. Trying to decide what I want to do for a manifold too. I've seen a few generic 8v T3 manifolds but it is hard to know what will fit!
Sent from my HTC One X using Tapatalk 2
Reply #6March 05, 2013, 12:10:21 pm
« Reply #6 on: March 05, 2013, 12:10:21 pm »
the generic ones are pretty useless...
Reply #7March 05, 2013, 12:29:48 pm
« Reply #7 on: March 05, 2013, 12:29:48 pm »
Useless how?  Useless as in they don't physically fit?  Useless as in they have poor flow characteristics?
The stock AHU manifold doesn't look particularly good:
...whereas a generic 8V T25 manifold looks like it'd flow a lot nicer:
...though I kind of suspect the turbo would be getting quite intimate with the firewall...
Reply #8March 05, 2013, 02:49:02 pm
MJF
  • 581
« Reply #8 on: March 05, 2013, 02:49:02 pm »
That generic T3 manifold has large open plenum which causes slow spooling. Stock AFN manifold is pretty good one.
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #9March 06, 2013, 08:20:55 pm
« Reply #9 on: March 06, 2013, 08:20:55 pm »
it also has a big restriction in the runners for #1 & #2 cyl..
HUGE hump blocking a good 20-30% of the runners.. ill take a pic some day..
yes, they have a large internal volume, making spool times slower..
Reply #10March 07, 2013, 09:50:05 am
« Reply #10 on: March 07, 2013, 09:50:05 am »
There's a couple others that I've found too, from SPA Turbo:
This one is a T25 flange rather than a T3, so it is smaller than it might appear:
http://www.designengineering.com/files/pdfs/spa/090308.pdf
This one looks like it has the smallest volume.  It is divided, but from what I have been reading there should be no issues running an open turbo on a divided manifold:
http://www.designengineering.com/files/pdfs/spa/090307.pdf
Either would most likely have to be set up with the turbo bottom mounted.
Reply #11March 14, 2013, 07:05:06 pm
« Reply #11 on: March 14, 2013, 07:05:06 pm »
both manifolds pictured are NICE pieces..
Reply #12March 14, 2013, 07:48:12 pm
« Reply #12 on: March 14, 2013, 07:48:12 pm »
They are both about $250. I'm probably going to go with the top one myself...
Reply #13March 19, 2013, 02:49:38 pm
« Reply #13 on: March 19, 2013, 02:49:38 pm »
bottom one is set up for an external wastegate, so if you run the top one, make sure you have an integral wastegate..
Reply #14March 19, 2013, 04:36:51 pm
« Reply #14 on: March 19, 2013, 04:36:51 pm »
Actually both have an external wastegate flange. The PDF files show the full dimensional drawings and things.
The turbo I'm planning on does have an internal wastegate either way though. The one problem I need to figure out is it has studs on two of the manifold flange bolts which may be a challenge with either of these manifolds.
