split alternator pulley
Topic: split alternator pulley (Read 2133 times)
February 05, 2013, 09:41:14 am
92EcoDiesel Jetta
February 05, 2013, 09:41:14 am »
I took the 24 mm nut off an alternator from a 91 Eco and to my surprise the pulley split in 2 pieces! Is that stock from the factory or after market? Is it so that you can use wider belts by adding shims?
February 05, 2013, 09:52:55 am
srgtlord
Re: split alternator pulley
February 05, 2013, 09:52:55 am »
Maybe vw went cheap or the pulley split at the welds...
February 05, 2013, 01:09:08 pm
February 05, 2013, 01:09:08 pm »
Most of the ones I've seen are split with shims for width adjustment.
February 05, 2013, 04:31:26 pm
February 05, 2013, 04:31:26 pm »
most of my pulleys are machined steel..
only one of them is the split style..
yes, you should be able to shim the pulley to take a wider belt..
