Author Topic: Bigger valves and better cam  (Read 13224 times)
Reply #30February 07, 2013, 06:21:46 am
Re: Bigger valves and better cam
« Reply #30 on: February 07, 2013, 06:21:46 am »
Its for motocross engines, they don't tend to last very long ;)
ahh, that makes sense..
i wonder if you can get dimpled valves in a size that fits our diesels?!
That and I bet even in high rev racing conditions the valves probably get gunked up and the dimples fill in a bit. Then it would be like a normal vavle again. Our diesels even more so than the gassers would tend to carbon up a little.
Reply #31February 07, 2013, 06:24:34 am
« Reply #31 on: February 07, 2013, 06:24:34 am »
So it's better to have a semi rough intake and a polished exhaust?
I think with my turbo setup and choices ill have problems keeping my head on the block. Has anyone figured out a way to keep these bolted down?
I wouldn't say rough, just not mirror. IIRC 120 grit finish is where mine was at. It isn't smooth, but it isn't rough. The 120 grit surface seems to grab your fingerprint a bit not much, when running across it. 80 I know was too coarse. I will see if I can post a pic of my intake I made as the welds were cleaned up with the same grit as the head.
Reply #32February 07, 2013, 06:44:15 am
« Reply #32 on: February 07, 2013, 06:44:15 am »
Old head pics
Reply #33February 07, 2013, 06:53:28 am
Jetmugg
  • 530
« Reply #33 on: February 07, 2013, 06:53:28 am »
Beautiful work on that intake. :o  Did you do the fab & welding yourself?
Steve.
Reply #34February 07, 2013, 06:58:48 am
« Reply #34 on: February 07, 2013, 06:58:48 am »
no. I haven't had much experience with a tig. A guy I have a customer I sell to and he did the welding, but I did all the fab and porting. I guess you could say I built it. I am more of a hammer guy and my tig customer is more of an artist. If you look at my sig there is a 'round 2' and page 2 that explains how it was built. SAUSAGE STUFFERS!!!
« Last Edit: February 07, 2013, 07:02:12 am by theman53 »
Reply #35February 07, 2013, 07:59:15 am
« Reply #35 on: February 07, 2013, 07:59:15 am »
run a different turbo that makes less drive pressure..
drive pressure is what kills these, not boost..
Reply #36February 07, 2013, 08:31:43 am
Hoble
  • 76
« Reply #36 on: February 07, 2013, 08:31:43 am »
Both turbos are pretty efficient and running 44mm wastegates. What's the best way to monitor that pressure?
I'm actually running a 1.8l 8v intake with the ports modified to fit the 1.9 D intake ports. Need to cut off the original tube and weld on something better. I am the active tig welder at the shop I work at. When it's done I'll post some pictures.
Reply #37February 07, 2013, 08:36:17 am
« Reply #37 on: February 07, 2013, 08:36:17 am »
if u have that intake with and with proper sized turbo u shouldn't have any issue.  just drill and tap a fitting in the exhaust manifold and watch your emp's just like u would watch boost pressure.
Reply #38February 07, 2013, 08:39:47 am
« Reply #38 on: February 07, 2013, 08:39:47 am »
yep, i finished mine with 120 grit then the machine shop i had do all the valve work sand blasted all the ports
here is mine u can see i didn't remove much of the hump around the valve guide, i guess i should have judging by how lucas's looks.:
and here is my exhaust manifold tapped for emp gauge, and a coil of copper to help keep the hose from getting hot
Reply #39February 07, 2013, 09:12:07 am
« Reply #39 on: February 07, 2013, 09:12:07 am »
1Y manifold is JUST what you need.. already has the D ports, and it is shaped almost identical to the mk2 1.8L intake mani..
no welding required, unless you want to completely remove the EGR accommodations..
Reply #40February 07, 2013, 11:58:50 am
Jetmugg
  • 530
« Reply #40 on: February 07, 2013, 11:58:50 am »
Don't know how I missed your "Round 2" build thread before, but I was missing out.   ;D  The sausage stuffer tubes look like they worked well for the transition pieces.
I like your idea & need to see how to approach my own intake project.  I just bought an ABL intake, I believe from a 1.9 Vanagon.  I'm planning to use that as my starting point.
Steve.
Reply #41February 07, 2013, 02:24:42 pm
carrizog60
  • 978
« Reply #41 on: February 07, 2013, 02:24:42 pm »
i have a 1y intake and it looks way better than gtd ones...
well i have 1Y all around and when i started the build i was told that they had the 7mm stem valves from stock...
Portugal
Reply #42February 08, 2013, 09:08:18 am
Hoble
  • 76
« Reply #42 on: February 08, 2013, 09:08:18 am »
I have more time than money and I would at a machine shop. Making an intake is easy for me. It would be harder to go find a 1Y intake an buy it and ship it. Plus this way it's all custom to what I want.
Side note, got some Alu pulleys made up for my motor at work, do you know the crank bolt hole pattern isn't really a pattern? They aren't in a circle at all and not symmetrical at all. Just kinda weird VW did that.
Reply #43February 08, 2013, 10:04:14 am
« Reply #43 on: February 08, 2013, 10:04:14 am »
IIRC, they just offset one hole a few degrees...?
Reply #44February 08, 2013, 10:38:16 am
Jetmugg
  • 530
« Reply #44 on: February 08, 2013, 10:38:16 am »
That's good to know.  I assume the bolt pattern is indexed like that so the pulley only goes on one way, thus allowing the timing alignment marks to be used.
Steve.
