Author Topic: Do I need this part  (Read 2635 times)
February 04, 2013, 12:27:13 pm
ein bora
  • 377
Do I need this part
« on: February 04, 2013, 12:27:13 pm »
I believe it's some kind of a vacuum canister and it sits on top of my aaz injection pump. It has a little cable going to the side of the pump that I'm sure does something. As this is my Giles modified pump that I'm using on my b5 gas to diesel swap can I just remove it.  The pump on my other aaz doesn't have one so I'm thinking it's not needed.
Any help appreciated. Thanks.
If you can't take advice - then you can't be helped!
Reply #1February 04, 2013, 04:36:01 pm
JamesT
  • 151
Re: Do I need this part
« Reply #1 on: February 04, 2013, 04:36:01 pm »
It's for a vacuum controlled high idle. It's usually found on cars with A/C. You don't need it, but it could be useful.
93 Golf - AAZ with some fueling
78 Rabbit - 1.5 DIESEL (finally)
[(+)===o===(+)]
 (++\==o==/++)
Reply #2February 04, 2013, 04:46:54 pm
wdkingery
  • 494
« Reply #2 on: February 04, 2013, 04:46:54 pm »
I read the title and I knew the answer was no before I saw the part lol
Reply #3February 04, 2013, 07:20:28 pm
ein bora
  • 377
« Reply #3 on: February 04, 2013, 07:20:28 pm »
Okay thanks; Good to know.
