Author Topic: Charging problem!  (Read 2260 times)
February 01, 2013, 05:41:02 pm
jaed_43725
Charging problem!
« on: February 01, 2013, 05:41:02 pm »
 >:( Ok, so when I start the car and blip the throttle to 2K it goes up normally. After that the tach just goes to like 600 RPM and then slowly drops from there. I can tell its not charging because the fuel gauge and water temp gauge both slowly fall. By slow here I am talking about 40 miles and the battery is dead. I have a new alternator which is tested good, the belt tension is good. The only thing that is old is this black thing on the back of the alternator that has a blade plug in and its held on by an 8mm bolt. Any help is greatly appreciated. I don't want to have to take this thing somewhere but if I have to I will.
Reply #1February 01, 2013, 06:50:31 pm
  • 4553
Re: Charging problem!
« Reply #1 on: February 01, 2013, 06:50:31 pm »
Perhaps a broken wire along the line somewhere.  Makes contact then does not.  Clearly you are not charging up.
Reply #2February 01, 2013, 07:11:42 pm
« Reply #2 on: February 01, 2013, 07:11:42 pm »
Not charging and/or the GP relay stuck.
Unless the accessories are on (lights, fan etc.) a battery should keep a diesel engine running for hours (if not days).
I would charge the battery and test:
 - Meter the battery, should be ~12.5V
 - With the ignition switch in the ON (run) position, but engine not running, the battery should read ~11.5V until the GP relay opens (~20sec), then back to ~12.5V.
 - Meter between battery neg and blue wire at the alternator D+ terminal should be ~1.5V.  The dash LED should be illuminated.
 - Meter between battery neg and big red cable at alternator B+ terminal should be ~12V.
Start the engine:
 - Wait ten seconds and rev the engine once to 2000rpm
 - Battery voltage should read ~13.5-14.5V
 - Blue wire at D+ terminal on alternator should read the same as battery
 - LED on dash should not be illuminated
If these check out ok, then it is likely a connection problem with grounding.
(The black module is a condenser to suppress RFI from interfering with your AM radio... not important.)
Reply #3February 01, 2013, 08:06:33 pm
« Reply #3 on: February 01, 2013, 08:06:33 pm »
Is this your new alternator. Might be better as a followup  to your original thread. "Whats the best alternator"
Keep reading.
TD Give up AM radio. No way, how am I going to find out what is going on the world.
Reply #4February 02, 2013, 04:27:17 am
jaed_43725
« Reply #4 on: February 02, 2013, 04:27:17 am »
I am gonna do the checking then. I hope its not serious, but then again there aren't many wires on this thing. I read somewhere someone changed all their little wires for substantially bigger ones and it made quite a difference. If everything checks out then I am gonna have to drop it off at Apex Tuning.
