Author Topic: Out Banjo persistant leak  (Read 17501 times)
Reply #60February 05, 2013, 06:56:44 pm
bbob203
  • 1789
Re: Out Banjo persistant leak
« Reply #60 on: February 05, 2013, 06:56:44 pm »
Td your troubleshooting techniques amaze me more and more every time.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #61February 05, 2013, 08:18:04 pm
« Reply #61 on: February 05, 2013, 08:18:04 pm »
I'm just happy to have found a use for the vinyl tubing that I'll never use for fuel lines.
As for the pressure at the bolt threads, a bit of poking around the webz reveals there are NPT threads, BPT threads, Metric Pipe Threads and the Germans have a unique thread also.
http://www.engineeringtoolbox.com/thread-standards-d_776.html
It is my impression that the threads seal most of the IP internal pressure from the banjo fitting.
Reply #62August 28, 2013, 07:17:56 pm
sgnimj96
  • 185
« Reply #62 on: August 28, 2013, 07:17:56 pm »
       Just for the record, after a couple of months of doing other stuff i found...  my ip return banjo WAS actually cracked (a micro crack at the small tube for the injector returns).        I replaced it  with a banjo fitting (single tube) from a fuel line replacement kit and added a stainless T fitting (1/4 1/4 1/8) for the injector returns to meet into the return hose.
  Definitely is a low-pressure fitting or fuel would have been spewing everywhere when I was driving around with that.  ::)
81 Scirocco 1.6D (conversion)    86 Gofl 1.6D      2003 Golf Tdi   1985 300TD
Reply #63November 01, 2013, 04:48:42 pm
« Reply #63 on: November 01, 2013, 04:48:42 pm »
Ja, them is inches... inches of ATF.
40 inches of ATF should be about 46" of water ("WC). (40/.87)
46 / 27.7 = 1.66psi.   So, the banjo outlet is handling ~1.7psi.
12/.87 = 13.8" of vacuum due to the tank means the IP out bolt orifice is actually outputting 59.8" WC of pressure, or 2.2psi... but the tank vacuum lowers the pressure in the fitting.
Your math might be a little off.  A lower specific gravity (0.87) will result in the higher reading, no?  Mercury has a much higher specific gravity than water and an inch of mercury is proportionately more pressure than an inch of water...  Shouldn't the 40 inches of ATF be multiplied by the specific gravity rather than divided by it?  That would mean 1.26 psi rather than 1.66 psi.  Regardless, the pressure is minuscule.
Reply #64November 01, 2013, 05:00:57 pm
« Reply #64 on: November 01, 2013, 05:00:57 pm »
Yes, quite right!
« Last Edit: November 01, 2013, 05:11:42 pm by TylerDurden »
