Author Topic: Whats the best alternator?  (Read 3255 times)
January 30, 2013, 05:20:50 pm
jaed_43725
« on: January 30, 2013, 05:20:50 pm »
Mine died on me so I am gonna replace it. But I would like to know what one is best and if there are any over 90A. Thanks for the input.
Reply #1January 30, 2013, 05:44:47 pm
nwcali6
  • 69
Re: Whats the best alternator?
« Reply #1 on: January 30, 2013, 05:44:47 pm »
  I have a 120 on my 96 TDI from the factory, have a spare 120 sitting on the shelf.  My 1.6 had a big truck 120 modded to it when I bought it.  I'd say stock, or if you want to add it, 120's are fairly common and the route I'd go.
Reply #2January 30, 2013, 06:33:49 pm
« Reply #2 on: January 30, 2013, 06:33:49 pm »
Be careful, stressing that crank pulley with too much load could cause the crank gear to crap out.. and the belt will come off......
Reply #3January 31, 2013, 12:08:03 pm
« Reply #3 on: January 31, 2013, 12:08:03 pm »
run the smallest alt you can, that will still meet your charging demands..
do you NEED a bigger alt than stock? got a big stereo, or lots of lights?
i run a HUGE stereo off a 120a TDI alternator, and 2 batteries..
what alternator do you have now? assuming a 90a? or does your car not have a/c? (65a alt w/o a/c)
Reply #4January 31, 2013, 01:09:42 pm
« Reply #4 on: January 31, 2013, 01:09:42 pm »
I have followed this thread,
Can appreciate the loads on the belt. 120 amps takes 4.5 horsepower to use it at it's rated power if it is 50% efficient. No wonder many have belt problems. It isn't free. The Mercedes 300D uses a 65a unit and it is driven by two v belts in parallel.
A pretty amazing amount of power is being used up, if you have it humming. Of course if you are just charging the battery back up from a start that output won't be that high for long still that is a lot of load on a cold belt. I figure that most who need it have much more going on than just transportation.
Reply #5January 31, 2013, 02:09:58 pm
jaed_43725
« Reply #5 on: January 31, 2013, 02:09:58 pm »
I went with a Ultima 90A. As I have A/C. There was one wire different the D+. But otherwise everything is good.
Reply #6January 31, 2013, 02:20:58 pm
« Reply #6 on: January 31, 2013, 02:20:58 pm »
At what point are your alternator wires going to be overheating.
Reply #7January 31, 2013, 05:05:19 pm
« Reply #7 on: January 31, 2013, 05:05:19 pm »
I run the same size charging wire as I do positive battery cable ;) as well as a ground from the case of the alt to my neg batt terminal.
I never have a dimming light, or any issues. For further clarification, I have 90/100W lows, 100w highs, 100w fogs, fairly big stereo (im 22, of course i do), fan on high, rear defroster.. doesn't even think about working for it ;) lmao. My lights alone pull 44a..
Reply #8January 31, 2013, 05:20:14 pm
« Reply #8 on: January 31, 2013, 05:20:14 pm »
Sounds like a plan having thick wiring. You can't go wrong with running battery cable to the alternator.
My car has a big fat expensive wire in it that was hooked to the battery and went into the trunk  where it terminated on a jumbo fuse block. The wire is the size of battery cable maybe 4/0, has a translucent red cover and has very fine stranded wires in it. Have no idea what it was for.
I disconnected it from the battery for safety. Thought that if I wanted to move the battery into the trunk it would make a nice cable. I would probably do that except that many times the car is loaded to the gills and it would mean leaving something behind. Back when I was 22 I had a new 73 toyota. I had the suspension cut down and the battery in the trunk. The car has been gone since 78 but I still have the cable, am pretty sure I paid about 34 dollars for it, the price of 100 gallons of gas at the time.
I listen to the AM radio on occasion but prefer silence, well not silence but not more additional noise.
Reply #9January 31, 2013, 07:09:53 pm
shorttimer
  • 121
« Reply #9 on: January 31, 2013, 07:09:53 pm »
I agree that beefy wiring is the way to go. Checking grounds is really key, too. Not to jack the thread. Another thing I do (I started doing it on winterizing my motorcycles first) is using a product called DeoxIT, by a specialty chemical company called Caig. It's used in applications for de-oxidizing electrical connections on high end audiophile gear. I stumbled across it many years ago & have found it to work fantastic. Works on any electronic connection. Just a very small spray is needed & then I pack the connector with dielectric grease, with my finger, for an impermeable connection. The connection can be submerged in water with no problems. If there is obvious corrosion sanding/wire brushing will help first.
Reply #10January 31, 2013, 07:22:43 pm
« Reply #10 on: January 31, 2013, 07:22:43 pm »
Scrounger, me tinks your car was owned by a young guy with a stereo.haha
shottimer, good info. I love die-electric.
Reply #11February 01, 2013, 01:43:40 pm
« Reply #11 on: February 01, 2013, 01:43:40 pm »
Will a 120amp tdi alternator drop right on to a 1.6td? Or is the bracket setup different?
you need an ABF alternator bracket, a TDI 120a alt, a VR6 water pump pulley or a TDI power steering pulley, a 1.8T harmonic balancer..
thats just to get you working without a/c or power steering..
and its a bad idea to run a serp setup on a diesel without doing the TDI crank sprocket mod.. you run the risk of twisting the end of the crank off, when running a serp setup on a stock 1.6 crank and sprocket..
