Author Topic: Wanted - AAZ exhaust manifold  (Read 8317 times)
January 25, 2013, 12:21:58 pm
Jetmugg
  • 530
« on: January 25, 2013, 12:21:58 pm »
Wanted - AAZ exhaust manifold.  Turbo preferred, but may be able to use a N/A  manifold.
Let me know what you have.
Steve M.
Reply #1January 25, 2013, 12:46:58 pm
rallydiesel
  • 1880
Re: Wanted - AAZ exhaust manifold
« Reply #1 on: January 25, 2013, 12:46:58 pm »
What kind of flange are you looking for?
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #2January 25, 2013, 01:05:08 pm
blackbird82
  • 151
« Reply #2 on: January 25, 2013, 01:05:08 pm »
I have one. with the integral turbo. the little guy. Instant boost! great in a city!
I love the whistle......
Reply #3January 29, 2013, 02:45:57 pm
Jetmugg
  • 530
« Reply #3 on: January 29, 2013, 02:45:57 pm »
I'm intending to use this for a land-speed racing application (1.5L diesel truck category).  Throttle response is not important.  Good flow is much more critical.
Steve.
Reply #4January 29, 2013, 05:27:52 pm
« Reply #4 on: January 29, 2013, 05:27:52 pm »
Steve, the 1.6 manifold will work and fit as they are the same.
Reply #5January 29, 2013, 08:39:45 pm
« Reply #5 on: January 29, 2013, 08:39:45 pm »
Turbo or naturally aspirated?
Reply #6January 30, 2013, 06:59:22 am
Jetmugg
  • 530
« Reply #6 on: January 30, 2013, 06:59:22 am »
Maybe I should modify, start over or re-phrase my request.  Some additional context might be helpful.  This is for a 1.5L / AAZ headed turbodiesel setup.  I already have a 1.6L non-turbo exhaust manifold sitting on the shelf, but to my eye, it looks like it wouldn't flow especially well.
Talking to my local turbo shop about this project, he recommended finding the best flowing exhaust manifold that would work with this head.  The turbo flange is not critical, but if a good flowing turbo manifold is available, that might help simplify matters (it also might not).  If I can come up with a good flowing exhaust manifold or shorty style tubular header, I can adapt the turbo flange from there.
The engine is going in a Dodge Rampage, and will be used for a Land Speed Racing attempt.  I am free to modify the firewall for turbo and exhaust clearance.  The turbo does not have to reside in a "stock" location like on a factory TD setup for a Golf/Jetta/etc. I will most likely have to weld a steel "box" onto the firewall, which will extend into the passenger's compartment to allow for additional space for the turbo and exhaust system.
I hope this explanation helps.  I think that perhaps I should start a new discussion on the regular technical board.
Steve
Reply #7January 30, 2013, 09:00:53 am
« Reply #7 on: January 30, 2013, 09:00:53 am »
Yes I am aware ;)
What I then would recommend is using the stock 1.6NA manifold.. as you will find from measuring the inner that mates to the exhaust system it should be like 2.5"! Most people only run 2.5" on a heavy turbo build.. So I think you will be fine to move all the air you need through that proper vw manifold.
Even take a look at the runners, they are a nice manifold. It was the downsize to 1" exhaust pipe that got them the bad rap. ;)))
Reply #8January 30, 2013, 09:17:12 am
Jetmugg
  • 530
« Reply #8 on: January 30, 2013, 09:17:12 am »
Thanks for the knowledge Jeremy.   ;D  I'll do a double check of the N/A manifold.  You may have just saved me a couple of hundred bucks.
Steve.
Reply #9January 30, 2013, 11:12:09 am
« Reply #9 on: January 30, 2013, 11:12:09 am »
Do you have a web page or pictures of your conversion. What is the record for the class?
Thanks.
Reply #10January 30, 2013, 11:25:20 am
Jetmugg
  • 530
« Reply #10 on: January 30, 2013, 11:25:20 am »
My build diary is here...
http://www.landracing.com/forum/index.php/topic,10625.0.html
The current record for a 1.5L diesel truck is right at 106 mph, timed over a running mile.  It's held by a guy driving a VW Caddy.
Steve.
Reply #11January 30, 2013, 11:35:55 am
« Reply #11 on: January 30, 2013, 11:35:55 am »
Oh yeah!
I was thinking of the big 4wd.
Reply #12January 30, 2013, 07:26:19 pm
« Reply #12 on: January 30, 2013, 07:26:19 pm »
I remembered you Steve. You will be running a turbo and probably would be easier to have a TD manifold. What I was saying was the 1.6 TD manifold would fit and work fine. The N/A you will have to cut and weld a flange of some sort to mate a turbo to. If you are cutting and welding I would look at some flow dynamics and just cut the flange off and weld yourself up one with new mandrel bent tube, probably 1.25" to 1.5" tubing. You would want it to not be any bigger than the port pre turbo.
Reply #13January 31, 2013, 08:32:27 am
Jetmugg
  • 530
« Reply #13 on: January 31, 2013, 08:32:27 am »
Gotcha.  What I was thinking of doing was using a short run of exhaust pipe from the factory non-TD manifold, then necking it down to blend into the turbo flange.
If the consensus is to start with a TD manifold to begin with, then that's the way I'll go.
Steve.
Reply #14January 31, 2013, 06:15:39 pm
« Reply #14 on: January 31, 2013, 06:15:39 pm »
Remember the longer you go away from the combustion the less energy the turbo will have as it will have more time for the exhaust to cool.
