Author Topic: my 500 dollar shiny turd  (Read 19859 times)
Reply #15January 27, 2013, 08:36:59 am
Re: my 500 dollar black shiny turd
« Reply #15 on: January 27, 2013, 08:36:59 am »
[Harsh truth removed]  ;D
« Last Edit: January 27, 2013, 01:48:46 pm by libbydiesel »
Reply #16January 27, 2013, 09:45:39 am
wdkingery
  • 494
Re: my 500 dollar shiny turd
« Reply #16 on: January 27, 2013, 09:45:39 am »
Awww LibbyBapa.. I didn't know you would be so upset by my car.
Well here, I'll fix the original post for you.. didn't wanna trample any toes.
Reply #17January 27, 2013, 09:53:35 am
« Reply #17 on: January 27, 2013, 09:53:35 am »
I'm not even remotely upset by you or your car.  I literally couldn't care less.  I just enjoyed pointing out the absurdity of it and your comments about it.  Maybe I'm a little like you and like poking you with a stick because it's obvious that you've worked extra-hard to make it an absurdly ugly mess of a vehicle with the obvious aim to poke a stick at other people.  I enjoy the hypocrisy and irony of it all.  Don't go getting all butt-hurt when someone uses your technique to call you on your own game. Carry on.   ;)
« Last Edit: January 27, 2013, 10:32:49 am by libbydiesel »
Reply #18January 27, 2013, 12:09:45 pm
« Reply #18 on: January 27, 2013, 12:09:45 pm »
That new updated pic looks AWESOME! See I knew it was at one time a clean car ;)
Reply #19January 27, 2013, 02:38:48 pm
tyb525
  • 183
« Reply #19 on: January 27, 2013, 02:38:48 pm »
So, what's your WMO set-up like?
2004 Golf BEW, '81 1.6 NA rabbit (soon to be parted out)
Reply #20January 27, 2013, 03:33:07 pm
wdkingery
  • 494
« Reply #20 on: January 27, 2013, 03:33:07 pm »
I buy this filter bag for $6 and just pour thru as needed. No real setup or anything. http://www.cfsco.net/fibagsvowvob3.html
Reply #21January 27, 2013, 04:08:15 pm
tyb525
  • 183
« Reply #21 on: January 27, 2013, 04:08:15 pm »
Hmm never seen one of those before, do you mix it with gas or diesel? I've read guys are using gas in 85% oil, and Diesel below 85%.
Reply #22January 27, 2013, 04:20:10 pm
wdkingery
  • 494
« Reply #22 on: January 27, 2013, 04:20:10 pm »
Hahaha believe I run it straight right now.. Haven't put a paid liquid in the tank in over 20 gallons now.
It seems the car likes a diesel mix. I was using gasoline, but it appears don't any of it mix too well. Even the ATF Will sit on top of the wmo. And I think the gas will sit on top of that.
If you can get it Started, it'll run on straight wmo.
Reply #23January 27, 2013, 04:22:59 pm
tyb525
  • 183
« Reply #23 on: January 27, 2013, 04:22:59 pm »
Strange, I haven't heard of the gas or diesel not mixing with the oil. It should all be inter-soluble.
Reply #24January 27, 2013, 04:24:13 pm
wdkingery
  • 494
« Reply #24 on: January 27, 2013, 04:24:13 pm »
I just dump each liquid in the tank.. Don't do too much agitating. I think if you premix it would do better
Reply #25January 27, 2013, 06:31:49 pm
shorttimer
  • 121
« Reply #25 on: January 27, 2013, 06:31:49 pm »
Just stand on the back bumper & bounce it up & down.
Reply #26January 27, 2013, 06:37:02 pm
« Reply #26 on: January 27, 2013, 06:37:02 pm »
Or drive it hard. I drive so hard sometimes, I can here the fuel slosh over the sound of my engine!
Reply #27January 27, 2013, 06:56:53 pm
tyb525
  • 183
« Reply #27 on: January 27, 2013, 06:56:53 pm »
Sounds like you have a pretty rough system lol, but hey if it works for you. I want to try this soon as I have about 55 gal of wmo I need to get rid of. I plan on filtering it into clean barrel and mix it with about 15% gas, then pumping it into the tank with a hand pump I have that screws into a bung on the barrel.
I have a ton of unused cone type paint filters, wonder if they would be fine enough, I'd like to get it about as clean as pump diesel. Otherwise I have some electric fuel pumps I can rig up to pump through a real filter.
Reply #28January 27, 2013, 06:58:39 pm
« Reply #28 on: January 27, 2013, 06:58:39 pm »
Its not the issue of filtering out particulate.. its the issue of the un-burnable additives in motor oil that makes the issue of running motor oil.
Reply #29January 28, 2013, 07:03:34 am
JBG3
  • 227
« Reply #29 on: January 28, 2013, 07:03:34 am »
why did you take down the original pics?  You might as well have fun with it, that car is a statement.  Just because people don't agree with you and don't like what you've done with the car doesn't mean you should edit things based on opinions on a forum.  Clearly, you have engineered the way the vehicle looks to provoke a reaction, and its done the same thing here.  Might as well sit back and enjoy it, its working perfectly as designed!
1986 1.6NA Jetta
