Author Topic: What is this thing?  (Read 5205 times)
January 19, 2013, 03:39:33 pm
What is this thing?
« on: January 19, 2013, 03:39:33 pm »
I should know what this does but don't? It is obviously a pressure sensor.
It is hooked to the intake manifold so it reads the boosted pressure and feeds into the fuel pump.
My guess is that it limits fuel until the boost builds.
Might get better response if it was removed.
Reply #1January 19, 2013, 03:43:02 pm
Re: What is this thing?
« Reply #1 on: January 19, 2013, 03:43:02 pm »
Is this on an eco? the lid looks different than normal 1.6TD lids.
You are right in your assumptions.
Take out the four screws and have a look see :)
Reply #2January 19, 2013, 03:50:50 pm
« Reply #2 on: January 19, 2013, 03:50:50 pm »
Mine is a fairly stock 86 non-catalyst. It does have hydraulic lifters in it.
Here is a more open photo.
Reply #3January 19, 2013, 04:00:12 pm
« Reply #3 on: January 19, 2013, 04:00:12 pm »
Lids just slightly different is all.
There will be no quicker fueling or spooling with it disabled. It senses boost and allows the pump to fuel accordingly.
You can turn that small screw on the very top in to start the boost pin further down its respective ramp allowing more fuel before boost picks up if you so desire.
I have my 88 1.6 TD setup with the star-wheel turned all the way in and using a softer 1.9 AAZ spring. I then have my top screw (off boost fueling screw) set so that I can a good haze going before boost picks up.. that little extra waste fuel does help spin the turbo up a wee bit quicker.. and hey belching soot looks cool ;)
Reply #4January 19, 2013, 08:11:27 pm
« Reply #4 on: January 19, 2013, 08:11:27 pm »
The "thing" is an aneroid actuator. On turbo models it is the LDA.
The manifold-pressure compensator (LDA) reacts to the charge-air pressure generated by the exhaust-gas turbocharger, or the (mechanical) supercharger, and adapts the full-load delivery to the charge-air pressure
Assignment
The manifold-pressure compensator (LDA) is used on pressure-charged diesel engines. On these engines the injected fuel quantity is adapted to the engine’s increased air charge (due to pressure-charging). If the pressurecharged diesel engine operates with a reduced cylinder air charge, the injected fuel quantity must be adapted to the lower air mass. This is performed by the manifold-pressure compensator which, below a given (selectable) charge-air pressure, reduces the full-load quantity.
Design and construction
The LDA is mounted on the top of the distributor pump. In turn, the top of the LDA incorporates the connection for the charge-air and the vent bore. The interior of the LDA is divided into two separate airtight chambers by a diaphragm to which pressure is applied by a spring. At its opposite end, the spring is held by an adjusting nut with which the spring’s preload is set. This serves to match the LDA’s response point to the charge pressure of the exhaust turbocharger. The diaphragm is connected to the LDA’s sliding pin which has a taper in the form of a control cone. This is contacted by a guide pin which transfers the sliding-pin movements to the reverse lever which in turn changes the setting of the full-load stop. The initial setting of the diaphragm and the sliding pin is set by the adjusting screw in the top of the LDA.
Method of operation
In the lower engine-speed range the charge-air pressure generated by the exhaust turbocharger and applied to the diaphragm is insufficient to overcome the pressure of the spring. The diaphragm remains in its initial position. As soon as the charge-air pressure applied to the diaphragm becomes effective, the diaphragm, and with it the sliding pin and control cone, shift against the force of the spring. The guide pin changes its position as a result of the control cone’s vertical movement and causes the reverse lever to swivel around its pivot point . Due to the force exerted by the governor spring, there is a nonpositive connection between tensioning lever, reverse lever, guide pin, and sliding-pin control cone. As a result, the tensioning lever follows the reverse lever’s swivelling movement, causing the starting lever and tensioning lever to swivel around their common pivot point thus shifting the control collar in the direction of increased fuel delivery. Fuel delivery is adapted in response to the increased air mass in the combustion chamber. On the other hand, when the charge-air pressure drops, the spring underneath the diaphragm pushes the diaphragm upwards, and with it the sliding pin. The compensation action of the governor lever mechanism now takes place in the reverse direction and the injected fuel quantity is adapted to the change in charge pressure. Should the turbocharger fail, the LDA reverts to its initial position and the engine operates normally without developing smoke. The full-load delivery with charge-air pressure is adjusted by the full-load stop screw fitted in the governor cover.
From: "Robert Bosch - Diesel distributor fuel-injection pumps VE" (available on the webz, gratis)
