the second test is a bit flawed, he's sucking all the air through a 3" square of filter not even pleated. This has to yield a much higher velocity and pressure than you cold ever hope to achieve with a full size filter. Also where one filter has 7 pleats, and another has 15, it won't show a difference despite one having 2x the area.
How does it cost more if it will outlast the car?Mine lists at $25, which adds up to a $46 K&N real fast.
TD air filters are NOT cheap around here, unless you want some cheap no-name, white box vato-zone, or O'reilly garbage...
IDK dude.. they run K&N filters on rigs that run the Dakar rally, the Baja 500 and 1000, as well as plenty of other dusty races..im gonna stand by what i said, if they are cleaned and oiled properly, they will filter almost as much dust out of the air as a paper filter, but with ALOT more flow..im gonna say that the guy you got your truck from, was an idiot, and probably used compressed air to blow the junk out of his K&N filter, and blew the gauze apart, leaving big holes in the filter media, just letting dust RIGHT THRU..ive run K&N filters on ALL of my ATVs and motorcycles.. they are often times ridden in VERY dusty conditions.. and ive never had a dirty intake duct, or dirty carb throat either..
Not to complicate things - but what about a Honda s2000 paper cone filter?http://www.canadapartsonline.com/air-filter/honda/s2000.htmlFrom what I can find Ford engines and some Chev vortex engines also use a paper cone- type filter. Maybe a trip to Napa might be in my future?Also found this '88 to '91 Honda Prelude Air Filterupdate: http://mymiata.paladinmicro.com/#DIYIntake So build an air box and change paper cone filters?
Paper filters out smaller particles and flow less air, are cheaper, and aren't reusuable.K&N filters slightly worse than paper, flow more air, are reusable, and are more expensive initially.Pick your poison, I don't think it as big of an argument as people on the internetz make it out to be. Kind of like the argument whether amsoil is actually good or not. I really don't care either way on the matter, I would run either filter and I have run both kinds on various vehicles and haven't had problems with either.Anyone else notice that first link seems to be biased towards ac delco? their products have always been viewed as pure crap by every mechanic I've known.
http://forums.tdiclub.com/showthread.php?t=290373
What isn't stated is that you can "tune" your car to the filter and intake setup. If you bolt on a filter setup and do not change anything fueling wise, nothing will happen. On my car I could run the fuel screw another 1/8 to 3/16 turn with the same EGT as before. If you have a computer car and you don't tune it, the filter will not add more fuel. It is just like a header or intake or muffler or anything that adds or reduces engine flow. You must tune accordingly. If you have a turbo with the potential to flow enough for 250HP but your pump settings are only ever going to give you enough fuel for 150HP you will never have 250HP. Same with filter. Most all of those tests were NOT maximized for the air flow the filter could give.I tried this myself with the TD airbox stock filter and the K&N pannel filter. The ammount of EGT and black smoke was crazy if I tried to keep the K&N settings with the stock Mann.
