Author Topic: Biggest battery to fit my 81 Caddy?  (Read 22865 times)
Reply #15December 31, 2012, 11:49:07 am
92EcoDiesel Jetta
Re: Biggest battery to fit my 81 Caddy?
« Reply #15 on: December 31, 2012, 11:49:07 am »
I bought the group 93 850 CCA battery from Advance for around $70 with the discount but have not picked it up yet. Figuring such a good deal I can't go wrong. I am also suppose to be getting a coupon $50 off a $100 purchase as part of the deal.
I have a blue top Optima in my Jetta that's more than 10 years old (my guess about 14) and no problems with it. If the group 93 won't fit in the Caddy, it may fit the Jetta and I'll just swap them.
Reply #16December 31, 2012, 11:51:12 am
92EcoDiesel Jetta
« Reply #16 on: December 31, 2012, 11:51:12 am »
This is my battery setup in the old flat red bunny and the MK2. Same 1/0 cable, same battery, just a different car. The battery actually fits better in the old 84 than it does in the 86. I think the a/c was the difference. It pretty much equalizes the weight of the engine lol. With 1000CA I never had an issue with cranking speed even if I wanted to glow the plugs 3 times in 0F weather.
That's a frickin big battery! How do you have it mounted? Surely the stock mount does not fit.
Reply #17December 31, 2012, 11:54:47 am
92EcoDiesel Jetta
« Reply #17 on: December 31, 2012, 11:54:47 am »
You may want to research residual capacity and amp-hours as well as these are particularly important for a diesel. The glowplug cycle draws a lot of current and a gasser battery may not have enough CA after a GP cycle or two. One of the best batteries for an IDI would be an OEM ALH battery. It's large and has the Ah that virtually no aftermarket battery can match. Only downside is it's expensive (usually close to $200 but some dealers sell it as low as $108).
I wish batteries are specified and rated in amp hours since it will make comparison so much easier. AFAIK no battery mfgs does that in the US.
Reply #18December 31, 2012, 12:14:02 pm
« Reply #18 on: December 31, 2012, 12:14:02 pm »
On my MK2 I had the rubber bungie strap and the one edge without the battery hold down. I forget on the MK1 I think it fit in the holder and just stuck out the one side. It has been too long. The 1/0 cable doesnt' really like to flex much so it will hold the battery in postition pretty much if you can get it to push the battery against the car.
Reply #19January 01, 2013, 02:14:04 am
sgnimj96
  • 185
« Reply #19 on: January 01, 2013, 02:14:04 am »
    That's a lot of battery for 70 bucks.     I missed out on the deal,  but mercedes battery is the same size and I have a optima battery that I bought off craigslist that I use on my computer UPS (beats buying the original little one).         Maybe when Advanced has another promo like that I'll get one.     http://www.techbargains.com/vendor_detail.cfm/4240/Advance-Auto-Parts-coupon-code
81 Scirocco 1.6D (conversion)    86 Gofl 1.6D      2003 Golf Tdi   1985 300TD
Reply #20January 01, 2013, 10:13:56 pm
  • 2932
« Reply #20 on: January 01, 2013, 10:13:56 pm »
       I'm wondering the same thing.   850 cca vs 650.  nice power difference.   The Group 93 battery is wider by about 4 inches http://www.rtpnet.org/teaa/bcigroup.     I need to get a battery for a mk1 scirocco,  unfortunately i don't have the car yet to measure if it will fit.      Modify the battery tray i guess,  would look something like this if you have the stock radiator:
What model VW is the pic below and what group # battery is it? Anyone else tried fitting a group 93 battery into a Caddy?
edit: My Caddy is not with me and I am trying to order the battery online before the deal ($40 off) expires today.
 A group 93, like Interstate's MTP93, will barely fit in an '84 Rabbit if you run the wires underneath the battery tray instead of next to the battery.
 The radiator is mounted different in an '84, probably an '83 too.
  It moves the radiator farther from the battery.
 Here's a pic of one in (pa)Tina:
 I can't get the G93 to fit the MK2s.
Reply #21January 03, 2013, 03:41:05 am
sgnimj96
  • 185
« Reply #21 on: January 03, 2013, 03:41:05 am »
        There you have it.       MK1!
 I've got to go pick up a 81' scirocco (with a 1.6 n/a conversion), check it out, and drive it from Texas to Florida to get it home.      I want a big battery just to have it.     Rumor has it that it has a fuel issue, so the bigger battery might really come into play.
Reply #22January 03, 2013, 08:27:22 am
« Reply #22 on: January 03, 2013, 08:27:22 am »
Type 34, just fitted one to the mk2 and it was small in there. Fully confident it will fit a mk1 way better. About two inches to the fender, and an inch and a half to the PS reservoir. Stock cables reached fine, although they are on my today's upgrade list ;) 00AWG baby! :)
1050 CA 875 CCA
Reply #23January 05, 2013, 09:34:52 am
92EcoDiesel Jetta
« Reply #23 on: January 05, 2013, 09:34:52 am »
The Advance group 93 battery does not fit in the 81 Caddy! It hits the fan shroud. It can be made to fit if the battery mount is moved towards the fire wall. My battery mount is a bit on the rusty side. Looks like it is welded in also. Has anyone replaced the battery mount? What's the best way for a new mount?
Here's a pic of the 93 battery sitting at an angle and not seated in the mount (sitting on top of it).
Reply #24January 05, 2013, 11:01:05 pm
  • 2932
« Reply #24 on: January 05, 2013, 11:01:05 pm »
What's the other side of the shroud look like?
 Is there a couple spacer mounts?
 Maybe you could swap them to the driver's side and move the shroud over.
 Maybe use an "S" clip instead of a "C" clip to mount it to the front.
 Same size battery as the one I pictured in my '84.
Reply #25January 05, 2013, 11:06:31 pm
« Reply #25 on: January 05, 2013, 11:06:31 pm »
Why modify to fit a 93?? The group 34 fits with room to spare in an mk2.. it will still be spacious in an mk1.
875 CCA, and a small package.. Cannot beat the value.
Reply #26January 06, 2013, 08:21:01 am
92EcoDiesel Jetta
« Reply #26 on: January 06, 2013, 08:21:01 am »
Because I bought one already (cheap) and it cannot be exchanged for a group 34 for the same price.
Last time I checked Advance, their group 34 silver battery was 660 CCA
http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_battery-group-size-34-660-cca-autocraft-silver_2040271-p
their group 34 gold was 800 CCA, no where near 875 CCA.
http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_battery-group-size-34-78-800-cca-autocraft-gold_2040409-p
Reply #27January 06, 2013, 09:54:51 am
bbob203
  • 1789
« Reply #27 on: January 06, 2013, 09:54:51 am »
I think i'm gonna pickup the autocraft gold 800cca 20%  of today better than the 550 i have now on a cracked and leaking die hard piece of sh-i-t.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #28January 06, 2013, 10:35:28 am
Reply #29January 06, 2013, 11:07:14 am
bbob203
  • 1789
« Reply #29 on: January 06, 2013, 11:07:14 am »
it pays to shop around. found a 1000ca 850cca at pep boys for 100 bucks group 34/78 I like having the dual terminal option on it. They also had a 20 dollars off 100 or more tempted to buy one for my passat for when i get the tdi in it.
« Last Edit: January 06, 2013, 12:09:58 pm by bbob203 »
03 Jetta wagon TDi
