Author Topic: 1.6TD rebuild questions  (Read 2759 times)
December 20, 2012, 05:13:35 pm
mattrose87
  • 21
« on: December 20, 2012, 05:13:35 pm »
so i keep reading about the oil/vacuum pump bushing can fall out in the hot tank. i didnt notice it before and dont know if it has fallen out, what does it look like and where is it?
also, when measuring the piston protrusion if i am doing it right i am getting .025" on all cylinders.  the spec in the Bentley book shows .026"-.030" for number one notch head gasket.  does my measurement of .025" sound right?
and i am thinking of using a stock head gasket with arp studs i reckon ill be ok with that just keep an eye on the gauges.
any pointers will be helpful
Reply #1December 21, 2012, 02:49:34 am
Re: 1.6TD rebuild questions
« Reply #1 on: December 21, 2012, 02:49:34 am »
Or skim the deck 0.001+ for an awesome sealing surface.
Reply #2December 23, 2012, 12:45:52 pm
« Reply #2 on: December 23, 2012, 12:45:52 pm »
if using a stock gasket, then stock TTY bolts are MORE than enough..
Reply #3December 24, 2012, 07:27:39 pm
mattrose87
  • 21
« Reply #3 on: December 24, 2012, 07:27:39 pm »
ok thanks block is off to the machine shop to get a shiny new top
Reply #4December 24, 2012, 09:20:50 pm
« Reply #4 on: December 24, 2012, 09:20:50 pm »
If you have a hydro block then shave off more so you're in the range of the 2 or 3 notch AAZ gasket.
Reply #5December 31, 2012, 02:30:12 pm
mattrose87
  • 21
« Reply #5 on: December 31, 2012, 02:30:12 pm »
mechanical block
