Author Topic: 1.6 td turbo flange gasket?  (Read 2887 times)
December 17, 2012, 09:37:35 am
jboogie13
  • 175
« on: December 17, 2012, 09:37:35 am »
I want to pull my turbo off so i can drill and tap for my EGT probe and im trying to assemble all the gaskets before beginning the job, what im a little confused about is the turbo flange gasket..is there one that is supposed to be there? A friend of mine who has access to ETKA says that one isn't called for, yet i see them for sale all over the place. hopefully someone can help?
Reply #1December 17, 2012, 10:02:29 am
Re: 1.6 td turbo flange gasket?
« Reply #1 on: December 17, 2012, 10:02:29 am »
The two stock engines I have here have no gasket between the exhaust manifold and turbo. They do have gaskets where the turbo meets the downpipe.
Reply #2December 17, 2012, 10:16:09 am
jboogie13
  • 175
« Reply #2 on: December 17, 2012, 10:16:09 am »
ok, i have the downpipe gasket. thanks for the confirmation on the turbo flange.
Reply #3December 17, 2012, 10:43:43 am
« Reply #3 on: December 17, 2012, 10:43:43 am »
100% correct. Also, if you remove the oil return line at the turbo you'll need a gasket there.
Reply #4December 17, 2012, 11:25:10 am
« Reply #4 on: December 17, 2012, 11:25:10 am »
FWIW, Hylomar makes exhaust flange sealant. That might be the shot on the flanges, gasket or not.
Reply #5December 17, 2012, 12:32:27 pm
« Reply #5 on: December 17, 2012, 12:32:27 pm »
I like to hand lap the mating surfaces using 120 grit paper and then seal with Permatex Ultra Copper.  I've done quite a few and never seen a single leak that way.
