Author Topic: GM Diesel Lift Pump/A Fitting Question  (Read 3057 times)
December 16, 2012, 06:54:43 am
ein bora
  • 377
« on: December 16, 2012, 06:54:43 am »
I wanted to install a lift pump on my b5 gas to aaz diesel project and after reading a number of old posts decided to go with the gm lift pump which is rated at 4psi. I have the pump on order so what I'd like to know is what the fitting sizes are so I can order the appropriate fittings. Just a long shot here but would anybody know that the sizes are? I'd like to pre-order the parts so I don't have to wait until after I get the pump.
Any help appreciated. Thanks.
If you can't take advice - then you can't be helped!
Reply #1December 16, 2012, 05:19:55 pm
Re: GM Diesel Lift Pump/A Fitting Question
« Reply #1 on: December 16, 2012, 05:19:55 pm »
My 6.2 uses 3/8 hose, but it's a mechanical pump.
Reply #2December 16, 2012, 07:24:02 pm
« Reply #2 on: December 16, 2012, 07:24:02 pm »
they take flare fittings.. 3/8, just like a 5.7 or 6.2d
Reply #3December 16, 2012, 09:56:42 pm
81 vw pu
« Reply #3 on: December 16, 2012, 09:56:42 pm »
Just did a 6.2  mechanical fuel pump yesterday, inlet is 3/8 barb not sure of outlet thread size, but it took a 5/8 wrench and was a flare fitting.
Reply #4December 17, 2012, 10:47:37 am
« Reply #4 on: December 17, 2012, 10:47:37 am »
3/8 coarse thread flare fitting.. promise.
just did a 5.7D lift pump not long ago..
all the fuel hard lines have 3/8 flare fittings. even at the fuel filter.
