General Information
General
Replacement hydro lifter doesn't "spring"
Topic: Replacement hydro lifter doesn't "spring" (Read 4227 times)
December 04, 2012, 12:25:32 pm
December 04, 2012, 12:25:32 pm »
Hrmmmm....
Two things I noticed when dropping in a replacement hydro lifter:
1) The replacement has a matte finish on the top, unlike the originals which are almost mirror shiny
2) The replacement does not have any give, or spring to it; unlike the originals which I can push down with my fingers.
Any tips?
(the original I am replacing was sticking. It was the lifter/follower, not the valve.)
December 04, 2012, 01:23:03 pm
Re: Replacement hydro lifter doesn't "spring"
December 04, 2012, 01:23:03 pm »
Brand new from my FLAPS...
The bit in the center will not depress.
Notice the charcoal finish on the top surface. The sides are shiny as expected. They fit in the bores properly.
Eh?
December 04, 2012, 06:31:43 pm
srgtlord
December 04, 2012, 06:31:43 pm »
I think they will be fine considering they are brand new.
December 04, 2012, 06:36:22 pm
December 04, 2012, 06:36:22 pm »
I'm feeling a bit better about em...
Closer inspection revealed that there is travel in the new lifters' springs, not nearly as much as the older ones.
New lifters: .012 -.015"
Old lifters: .090 - .120"
The shoulder surrounding the center tip seems to be crushed or folded like a turtleneck on the older lifters, allowing more travel... (maybe it's part of the design?).
The wear on the older tip is about .003".
The matte surface vs. the older shiny surface
December 04, 2012, 08:13:38 pm
rallydiesel
December 04, 2012, 08:13:38 pm »
The matte coating is a nitride layer to help with break-in. As far as the compressibility goes, the tdi engines have the small travel. Make sure to check you have the right part # but they may have updated idi lifters to the tdi ones.
1991 Jetta TD - sold
2001 Golf TDI - Son's
December 05, 2012, 10:25:23 am
December 05, 2012, 10:25:23 am »
Looks like one-fits-all these days.
Any thoughts on pre-filling the lifters before installation?
December 05, 2012, 09:01:48 pm
cyrus #1
December 05, 2012, 09:01:48 pm »
I always try to fill mine. I leave them in an oil bath upside down overnight and then try to work any air out by hand. Make sure to let the engine sit for a couple hours before turning over to allow the lifters a chance to bleed down.
Cody
2002 Jetta TDI
2000 Jetta TDI - R.I.P.
December 06, 2012, 04:25:50 am
December 06, 2012, 04:25:50 am »
always do 24 hours in atf
Round 2
General Information
General
