Author Topic: manifold leaking  (Read 3156 times)
February 25, 2006, 11:41:19 pm
samuraikid
  • 39
manifold leaking
« on: February 25, 2006, 11:41:19 pm »
ok having troubles getting my turbo to seal on the manifold. tryed a hi temp sylicone and it still blew it out. thinking I have to make a layered steel/copper gasket. but not sure where to buy some thing like that
Reply #1February 26, 2006, 05:57:21 am
Dr. Diesel
  • 1341
manifold leaking
« Reply #1 on: February 26, 2006, 05:57:21 am »
it's a metal on metal connection. if it's not sealing, and you're using the right bolts torqued properly, you'll need to have the sealing surface(s) remachined flat.
Reply #2February 26, 2006, 09:23:08 am
hillfolk'r
  • 1532
manifold leaking
« Reply #2 on: February 26, 2006, 09:23:08 am »
if ya had the manifold off you may be able to lap it at home,,turbo too,,,if ya had the turbo off is try lapping/surfacing that myself,,and check the manifold with a straightedge,,ya may be able to get lucky,,,,i know its metal to metal connection,,nogasket,,,but for safety iusually take some permatex ultra copper and just put like a thin thin dab around the port,,by a little imean enough tobarely leave color,,not a big nasty bead,,,if ya had a machine shop around,,it would be like 20-30 $ tosurface it,,,,,see i got a big nasty belt sander,,heehee,thats how i did mine,,at work,on smaller parts we use the same thing
Throttle cables ftw
Reply #3February 26, 2006, 04:14:20 pm
samuraikid
  • 39
manifold leaking
« Reply #3 on: February 26, 2006, 04:14:20 pm »
cool thanks for the tips guys. belt sander it is!
