Author Topic: timing aaz with adjustable sprocket  (Read 5613 times)
December 02, 2012, 07:47:32 pm
wadem
  • 32
« on: December 02, 2012, 07:47:32 pm »
Hi again guys, got the pump seals in and back on the car...YIPES, big job, for me anyways. I have read so many posts on IP timing that my head is spinning. What is the proper way to time the pump when you have the adjustable pump sprocket?  Do you require the dial tool or not? Some say do it the same as the ones with the adjustable pump body, while others say that with the adjustable sprocket you just line everything up and your good to go.
  So the long and short of it is......How do I set the timing on my 96 AAZ?
By the way, its all back together and running fine, no leaks..yet! It just sounded a bit smoother before i took it all apart.....wondering about the timing. When everything is all lined up,#1 TDC, Cam locked, the pump line up hole is about 1/16" of center....could this be it?
Wade
1996 Jetta 1.9 AAZ, addicted to Diesels!!!
340K and counting!!!
Reply #1December 02, 2012, 08:55:53 pm
Re: timing aaz with adjustable sprocket
« Reply #1 on: December 02, 2012, 08:55:53 pm »
Could very well be.  The lock, and pins just are for getting it near close enough that you can make it run.  If you want it to run right then you need to time it.
Reply #2December 03, 2012, 06:54:51 am
« Reply #2 on: December 03, 2012, 06:54:51 am »
Those pumps don't require a gauge to time but you need to have the pump hole lined up perfectly. If you have a gauge you may as well use it though.
Reply #3December 03, 2012, 10:59:10 am
wadem
  • 32
« Reply #3 on: December 03, 2012, 10:59:10 am »
Ya, like I said, it seems to be running fine just sounds a little different then it did before. I will try to perfectly match up the timing hole and see if it makes a difference.........stay tuned!
Wade
Reply #4December 03, 2012, 02:29:50 pm
wadem
  • 32
« Reply #4 on: December 03, 2012, 02:29:50 pm »
So, re adjusted the timing again and its unbelievable what a difference adjusting only 1/32 of an inch can make. So for now i'm happy with just lining everything up as again its running very well! Hopefully my re-seal job holds!
  One last question, on the adjustable IP sprocket, when your facing the sprocket from the passenger side of the car, is turning the pump shaft advancing or retarding the timing?
Cheers
Wade
Reply #5December 03, 2012, 02:40:40 pm
410
  • 581
« Reply #5 on: December 03, 2012, 02:40:40 pm »
Turning the pump shaft clockwise would advance the timing.
Reply #6December 03, 2012, 06:25:05 pm
bbob203
  • 1789
« Reply #6 on: December 03, 2012, 06:25:05 pm »
can these sprockets be used on the 1.6's or tdi's?
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #7December 03, 2012, 06:39:16 pm
« Reply #7 on: December 03, 2012, 06:39:16 pm »
Physically you can mount them. The offset is going to be off though, and without the matching pump body, you won't be able to lock them in the proper position.
Reply #8December 03, 2012, 06:52:04 pm
bbob203
  • 1789
« Reply #8 on: December 03, 2012, 06:52:04 pm »
so if I stuff the 1.6 guts into a 1.9 it will work?
03 Jetta wagon TDi
Reply #9December 03, 2012, 06:58:56 pm
« Reply #9 on: December 03, 2012, 06:58:56 pm »
Just use a 1.9 pump. Much less trouble.
Reply #10December 03, 2012, 08:48:33 pm
« Reply #10 on: December 03, 2012, 08:48:33 pm »
All the 1.9 pumps I have seen with the adjustable pulley for timing have had the larger pump snout yes? Bbob you wish to use this on a 1.6 I presume? You will need the AAZ bracket to do so.
Reply #11December 04, 2012, 05:08:03 am
« Reply #11 on: December 04, 2012, 05:08:03 am »
You are correct Jeremy.
Reply #12December 04, 2012, 09:11:37 am
410
  • 581
« Reply #12 on: December 04, 2012, 09:11:37 am »
I don't think the aaz bracket fits the 1.6 engine.  You would have to bore out a 1.6 bracket to fit the aaz pump snout.
Reply #13December 04, 2012, 09:48:47 am
« Reply #13 on: December 04, 2012, 09:48:47 am »
Hmm. I disagree. I have a 1.6TD bracket on an AAZ in my driveway right now, and it was the larger snout pump style AAZ too.  I do not know why, but I switched brackets so I could switch back to a twist-able pump instead of pulley.
So summary;
1996 AAZ block
1993 AAZ pump
1991 1.6TD bracket
