Author Topic: Exhaust mani flip, who's done it?  (Read 5667 times)
December 02, 2012, 08:32:49 am
« on: December 02, 2012, 08:32:49 am »
Who has successfully done this on a non mk1 car? I'm considering doing it on my mom's B3 but all the threads I've read seem to indicate it's impossible. Has anyone actually done it?
Reply #1December 02, 2012, 08:39:51 am
Re: Exhaust mani flip, who's done it?
« Reply #1 on: December 02, 2012, 08:39:51 am »
I haven't done it either.  So I won't give any input!!! Haha I have heard it doesn't work either tho,  I've seen them on cross flow engines but they're not flipped for that.
Reply #2December 02, 2012, 11:10:38 am
JFettig
  • 82
« Reply #2 on: December 02, 2012, 11:10:38 am »
Trapazoid flipped and adapted.
Took some machining to the flange where it bolts to the head to allow the intake manifold to bolt up, otherwise it interferes.
Reply #3December 02, 2012, 01:57:30 pm
CrazyAndy
  • 739
« Reply #3 on: December 02, 2012, 01:57:30 pm »
May I ask what benefits this would provide?  Ability to mount a larger turbo without risk of hitting the bulkhead?
Reply #4December 02, 2012, 02:32:16 pm
« Reply #4 on: December 02, 2012, 02:32:16 pm »
It's usually done to allow a better intake manifold to be installed.
Reply #5December 02, 2012, 03:09:05 pm
CrazyAndy
  • 739
« Reply #5 on: December 02, 2012, 03:09:05 pm »
Ah, I see, that would allow a less aggressive bend in the intake manifold tubes where they connect to the head, helping airflow.  That's a cool idea; I'll keep that in mind if I ever get the chance to use it!
Reply #6December 02, 2012, 05:30:05 pm
« Reply #6 on: December 02, 2012, 05:30:05 pm »
Gas intake is the usual suspect,
Reply #7December 02, 2012, 07:39:24 pm
« Reply #7 on: December 02, 2012, 07:39:24 pm »
Something looking like this goofy setup?  Odd looking duck.
http://images.craigslist.org/3n63F33Hf5E25K65J9cc1db70fdf0d3a71151.jpg
Off a Craigslist ad.
I wonder if R.O.R. was busy this weekend in an odd sort of welding way?
Reply #8December 04, 2012, 04:19:47 pm
CrazyAndy
  • 739
« Reply #8 on: December 04, 2012, 04:19:47 pm »
I don't like the looks of that exhaust manifold; looks like they just made it out of pipe, didn't bend the inner manifold pipe merges, and cut a hole where they all join and just welded the flange on.  Not very good for nonrestrictive gas flow.  DP needs work too, that sharp bend looks assty.
Dig the turbo and intake, though.  What turbo is that? (Sorry for OT ADD).
Come to think of it I have seen some folks run a K-jet mani on 1.6TD's with the injector holes plugged.  D ports really limit the AAZ/TDI crowd's options of doing the mani flip since they only seem to have those kind of ports.
Reply #9December 05, 2012, 11:32:16 am
« Reply #9 on: December 05, 2012, 11:32:16 am »
the injector ports are in the head tho??
ive run a flipped manifold with an audi 2.0TD turbo.
you have to grind a bit of the flange away to make the manifold fit when its flipped..
believe i had to grind the intake a bit as well..
it CAN be made to work.. there isnt much gain to be had from it, unless you want a long runner intake manifold..
no Dale, i would NOT build something that hideous.. that manifold is horrid.
that turbo looks to be a chrysler T3 turbo..
Reply #10December 05, 2012, 01:37:50 pm
Swartzvw
  • 53
« Reply #10 on: December 05, 2012, 01:37:50 pm »
I think he is talking about the cold start injector.
84 VW Rabbit w/ VNT 17
87 VW Jetta GL
