Author Topic: Pics of my newly made "log style" intake and IC install.  (Read 13243 times)
Reply #15December 10, 2012, 12:38:27 pm
Sierra94
  • 123
    Dieselsmoke in every stroke... M-Tdi Mazda!!
    • http://www.garaget.org/sierra94
Re: Pics of my newly made "log style" intake and IC install.
« Reply #15 on: December 10, 2012, 12:38:27 pm »
Yes, my IP flows fuel like crazy. I even get black smoke at thoose pressures. I could use a wastegate  ::) Or get a 10-11 mm head for the IP. It fuels pretty much even with the fuelscrew way out. With my old K24 and T3 it peaked at 35 psi without wg. I broke 3 turbos in one summer. The axle snapped just behind the turbine wheel on all 3, sending the turbine wheel all the way out the exhaust, ground down to a small ball in size  ;D
After that I started using my wastegate. But then I made the switch over to the dark side (vnt GT18) but still run without vane controller. The boost comes on at 2200 rpm anyway.
<-- My M-tdi Mazda B-1800 and my other cars
Reply #16December 10, 2012, 02:42:46 pm
snakemaster
  • 405
« Reply #16 on: December 10, 2012, 02:42:46 pm »
nice ,what gearbox/adapter plate you got there any pics , would love a RWD MTDI sport gld drift master set up .
Reply #17December 10, 2012, 08:58:50 pm
Sierra94
  • 123
« Reply #17 on: December 10, 2012, 08:58:50 pm »
I made it myself. I did a template out of MDF board and aftera testfit in the car I had a small weldingcompany cut it out of a 12 mm steelpate.
« Last Edit: December 11, 2012, 12:49:13 am by Sierra94 »
Reply #18December 10, 2012, 09:03:20 pm
« Reply #18 on: December 10, 2012, 09:03:20 pm »
So you have a 9mm pump, that blows black smoke at 30psi with the vanes open ???
I feel that something is not adding up here and that you may be having issues. What all has been done to the pump??
Reply #19December 10, 2012, 09:50:19 pm
Sierra94
  • 123
« Reply #19 on: December 10, 2012, 09:50:19 pm »
No no no. 12mm, built properly as M-tdi pump. Check the M-tdi pump faq. I made a couple of posts back when I built it. So nothing wrong with it.
How is it possible you misundersttod that I had a 9mm head on when I wrote that I would want less fuel out of my ip by installing a 10-11mm head??  ::)
« Last Edit: December 10, 2012, 09:57:10 pm by Sierra94 »
Reply #20December 11, 2012, 04:16:52 am
snakemaster
  • 405
« Reply #20 on: December 11, 2012, 04:16:52 am »
that plate looks good , a audi 80 tdi a4 starter? what gearbox and flywheel you using
Reply #21December 11, 2012, 04:33:31 am
Sierra94
  • 123
« Reply #21 on: December 11, 2012, 04:33:31 am »
Itīs an audi 80 td starter and a gasser audi 80 flywheel and pressure plate. KEP 4 puck sinter clutch plate and a volvo 740 M47, 5 speed gearbox. And a volvo 240, dana 30 rearaxle. 3.54 gear.
Reply #22December 11, 2012, 04:44:45 am
Sierra94
  • 123
« Reply #22 on: December 11, 2012, 04:44:45 am »
And some ready pics of it ready, sorry again for the bad quality.
Reply #23December 11, 2012, 08:00:31 am
« Reply #23 on: December 11, 2012, 08:00:31 am »
That was the root of my confusion, plus the fact I didn't even realize I was in a M-TDI thread.
What are your EGT's whilst at 30 psi and blowing black?
Reply #24December 11, 2012, 08:28:18 am
Sierra94
  • 123
« Reply #24 on: December 11, 2012, 08:28:18 am »
It's around 800 degres celcius. But that was before my IC install and with water/meth injection. And I have 3 inch exhaust from turbo and back.
Reply #25December 11, 2012, 08:38:36 am
« Reply #25 on: December 11, 2012, 08:38:36 am »
So with egts in check it would seem your turbo is too small for this application.
Yet its not causing stupid egts as a restriction.
Reply #26December 11, 2012, 10:47:27 am
Sierra94
  • 123
« Reply #26 on: December 11, 2012, 10:47:27 am »
Yes, I need a 2056 or a 2256. I can borrow a turbo from a friend. Itīs from a bmw x5 diesel.
Reply #27December 17, 2012, 10:57:19 am
« Reply #27 on: December 17, 2012, 10:57:19 am »
should be equipped with a 2056V
thats the turbo you need on that truck...
i LOVE my 2056 i have on my 1.6D, and i still have a 9mm plunger.
Reply #28December 17, 2012, 01:46:57 pm
Henk
  • 111
« Reply #28 on: December 17, 2012, 01:46:57 pm »
GT2052V off the Audi A4 V6 TDi is fairly available over here, not sure about for you guys in the US, but I got mine for i guess ~$100
sounds like the 22 might well be the better bet though!
Mid Engine
Berg Cup
M-TDi
Caddy!
Reply #29December 17, 2012, 03:53:05 pm
« Reply #29 on: December 17, 2012, 03:53:05 pm »
2052v isnt as capable as the 2056v or 2256v
the 56mm exducer vnts are better..
