Author Topic: Is this a W terminal alternator?  (Read 13617 times)
November 28, 2012, 03:44:01 pm
92EcoDiesel Jetta
« on: November 28, 2012, 03:44:01 pm »
I snapped this pic of the alternator p/n 175 903 023P on my 81 Caddy before it got dark and didn't have time to investigate further. There is a plug with 3 wires going to the alternator, there are no screw terminals or spade lugs like the alternator on my 92 Eco. Having 3 wires suggests it is a W terminal alternator: One wire to the battery for charging, one wire for the excitation. I am hoping the 3rd wire is the W terminal and I hope it runs all the way up to the correct pin in the cluster connector. I just modded a gasser tach to diesel per regcheesman's writeup and looking forward to installing it and see if the tach works.
Reply #1November 28, 2012, 04:08:47 pm
CarlosA
  • 139
Re: Is this a W terminal alternator?
« Reply #1 on: November 28, 2012, 04:08:47 pm »
Don't you own a flashlight? lol
I have a very similar alternator with only a few digits different in the numbers. Mine has a W terminal and the photo below shows where it is (right side of the back of the alternator when sitting in its mounted position).
And here is the tag on mine:
Reply #2November 29, 2012, 01:54:44 am
JamesT
  • 151
« Reply #2 on: November 29, 2012, 01:54:44 am »
The three wires in that plug are B+, B+, and D+.  The two fat red ones go to the battery (sometimes by way of the starter motor) and the other one, usually blue goes to the charging light.
My alternator has a terminal that looks like the W on the second one posted, but isn't a W signal.
93 Golf - AAZ with some fueling
78 Rabbit - 1.5 DIESEL (finally)
[(+)===o===(+)]
 (++\==o==/++)
Reply #3November 29, 2012, 05:29:03 am
92EcoDiesel Jetta
« Reply #3 on: November 29, 2012, 05:29:03 am »
Thanks for the info! Looks like I'm gonna have to pull the alternator, solder a wire onto a diode and make it a W terminal unit. At least it looks easy compared to my 92 Eco with AC, one belt and it's off!
Reply #4November 29, 2012, 12:01:08 pm
« Reply #4 on: November 29, 2012, 12:01:08 pm »
Autozone alternators have w terminals and cost about 60 bucks
Reply #5November 29, 2012, 02:16:45 pm
92EcoDiesel Jetta
« Reply #5 on: November 29, 2012, 02:16:45 pm »
Good to know! What year and model should I ask for? Note that mine makes the connection to the alternator via one 3 prong molded rubber plug (with 3 female spade terminals in it). No AC.
Reply #6November 29, 2012, 06:25:52 pm
« Reply #6 on: November 29, 2012, 06:25:52 pm »
My car is an 81 Rabbit pa with ac
Reply #7November 29, 2012, 07:21:17 pm
92EcoDiesel Jetta
« Reply #7 on: November 29, 2012, 07:21:17 pm »
Does "Autozone alternators have w terminals and cost about 60 bucks " still apply to my Caddy?
Reply #8November 30, 2012, 04:44:14 am
« Reply #8 on: November 30, 2012, 04:44:14 am »
yes, the only difference is the ac. just go order one, if it shows up with out the w terminal tell them you don't want it, it doesn't cost you anything.  i ordered 4 alternators through napa, the first one i just hope it was right, then the second one they actually called the warehouse and told them specifically not to send it unless it had the w terminal, they did that 3 more times, then i just went to autozone.  i work for napa and get an employee discount so i was trying to go there first.
Reply #9November 30, 2012, 08:29:18 am
92EcoDiesel Jetta
« Reply #9 on: November 30, 2012, 08:29:18 am »
Autozone only has the AC alt ($59). The non AC alt is $79 but not available from their supplier so I', SOL. I already have my alternator out and will take the cover off to get to the diodes and bring the W terminal out. This Motorola alternator has the regulator in a separate module from the brushes, unlike the Bosch which is in one assembly. Did 81 Caddy w/o AC come with Motorola alternators exclusively or did it also come with Bosch?
Reply #10November 30, 2012, 08:48:31 am
srgtlord
  • 797
« Reply #10 on: November 30, 2012, 08:48:31 am »
The truck my cousin has sitting in his yard has the the motorola alternator, so I am goin out on a limb and saying yes.
Reply #11November 30, 2012, 09:54:46 am
« Reply #11 on: November 30, 2012, 09:54:46 am »
Motorola alts were junk.. i just scrapped a big pile of them.
i always replace them with bosch units. ive found that the early-ish rabbits had the moto..
but the motorolas were interchangable with the bosch unit, and cheaper, so people often times bought the moto as a replacement for the bosch.
Reply #12November 30, 2012, 12:07:55 pm
92EcoDiesel Jetta
« Reply #12 on: November 30, 2012, 12:07:55 pm »
Why are Motorola alt junk and what fails in them?  Do you have a good Bosch non AC alt with a W terminal you want to sell?
Reply #13November 30, 2012, 12:22:17 pm
92EcoDiesel Jetta
« Reply #13 on: November 30, 2012, 12:22:17 pm »
I've soldered a wire to the diodes to bring out the W terminal (shiny solder spot at 10 o'clock in the pic). Next reinstall then test and see if the tach works.
Reply #14December 01, 2012, 09:10:03 am
« Reply #14 on: December 01, 2012, 09:10:03 am »
i hope you have put it in the right spot, other wise you could potentially be supply the tachs w terminal with un regulated voltage, to create a w terminal i believe you want to tap into just one of the three black wires.
