Author Topic: Fuel pump gasket/seal kits?  (Read 3567 times)
November 23, 2012, 02:27:46 pm
Bugsy_malone 666
  • 178
« on: November 23, 2012, 02:27:46 pm »
I been looking on ebay and relatively cheaply you can get a bosch fuel injector pump seal/gasket kits, problem is how many different types are there likely to be?
I know one kit mentioned a 'VE' pump, but how do I determine what I need and how many pump types do vw use on this early 1.6TDs?
basically I have a 1.6TD pump spare that I'd like to perform an overhall on in the sense of checking wear and looking up the governer mod as I been having issues with my current engine with poor starting and figured maybe I need to get on with rebuilding this pump that bought for this reason.
Reply #1November 23, 2012, 05:09:13 pm
Re: Fuel pump gasket/seal kits?
« Reply #1 on: November 23, 2012, 05:09:13 pm »
The two common kits are DGK-126 (for the NA) and DGK-121 (for TD & ADA).
The main input shaft seal: 1 460 283 312
More discussion here: http://www.vwdiesel.net/forum/index.php?topic=22904.0
