Author Topic: Final word on lowered injector pressures on a td..  (Read 2917 times)
November 22, 2012, 05:14:17 am
bbob203
  • 1789
« on: November 22, 2012, 05:14:17 am »
I've read different places here and on the hillbilly forum that na spec injector pressure might be better on a td than the factory higher pressure of td injectors. Reason I ask is I bought an 86 na golf with rebuilt injectors and rebuilt pump on a locked up motor. My injectors could stand to be spruced up so I was thinking of swapping these out.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #1November 22, 2012, 09:48:51 am
Re: Final word on lowered injector pressures on a td..
« Reply #1 on: November 22, 2012, 09:48:51 am »
only once have i ran real TD injectors..
i personally, liked the feel of the n/a injectors..
took out a set of rather fresh TD infectors, and installed a 15k mile set of n/a injectors..
the performance gains people feel might be because the 130bar injector opens sooner than the 155bar injector (advanced timing basically)
have you tried to free the engine up?
Reply #2November 22, 2012, 11:47:24 am
bbob203
  • 1789
« Reply #2 on: November 22, 2012, 11:47:24 am »
I havent been able to touch the car yet. Its five hours away I put a deposit on it site unseen just because the dude said it had rebuilt injectors and pump it was worth it for what im paying(and i didnt want it to get crushed with a bunch of useable stuff on it) also has some pretty new tirs on it and new brakes. He said he was driving it and it shut off and he tried turning it with a socket and it wouldnt move.
03 Jetta wagon TDi
Reply #3November 22, 2012, 12:43:36 pm
« Reply #3 on: November 22, 2012, 12:43:36 pm »
sounds like with a good head, and a new timing belt it would be back on the road again..
unless it bent a rod when it squished the valves  :-\
Reply #4November 22, 2012, 03:01:34 pm
bbob203
  • 1789
« Reply #4 on: November 22, 2012, 03:01:34 pm »
Thing is the dude said the tbelt is new and intact.
03 Jetta wagon TDi
Reply #5November 22, 2012, 03:27:24 pm
  • 4549
« Reply #5 on: November 22, 2012, 03:27:24 pm »
Skipped a tooth or two and that might be easy to correct and hope no valves are ruined in the process.
Reply #6November 22, 2012, 03:32:00 pm
bbob203
  • 1789
« Reply #6 on: November 22, 2012, 03:32:00 pm »
im gonna explore this idea. Only thing is he was driving so i think there is probably some internal damage done.
03 Jetta wagon TDi
Reply #7November 23, 2012, 12:13:51 pm
« Reply #7 on: November 23, 2012, 12:13:51 pm »
if he was driving when it locked, and it is STILL locked, then its prolly got internal damage..
hope that you can separate the engine and trans, and find a bunch of broken flywheel bolts :P
