Author Topic: caddy cluster wiring  (Read 1938 times)
November 18, 2012, 11:35:23 am
92EcoDiesel Jetta
« on: November 18, 2012, 11:35:23 am »
A2resource has a real nice pinout chart of CE1 and CE2 electrical  Is there one for Caddy electrical?
Specifically, does the red/ black wire from the cluster harness connector ((tach signal in a gasser caddy) go down to the fuse block onto the engine bay of a diesel caddy? I could rip everything apart and trace the wire but don't really want to/ have to if such a pinout diagram exist.
Reply #1November 18, 2012, 01:28:44 pm
Re: caddy cluster wiring
« Reply #1 on: November 18, 2012, 01:28:44 pm »
shift light??? 82+ = dynamic oil pressure and shift light... if so yes... if no nope.. you will need to add wire..
Reply #2November 18, 2012, 01:41:38 pm
92EcoDiesel Jetta
« Reply #2 on: November 18, 2012, 01:41:38 pm »
Do you know where the shift light wire go to in rhe fuse block (connector/pin)?
edit:
The red/black wire is on pin 5 of the cluster harness connector.
« Last Edit: November 18, 2012, 01:49:07 pm by 92EcoDiesel Jetta »
