injector removal problem when car has N/A pump?
Topic: injector removal problem when car has N/A pump? (Read 2863 times)
November 14, 2012, 11:21:37 am
derekp
November 14, 2012, 11:21:37 am »
I put an N/A pump on my eco 92 jetta a while back.
Head gasket woes causing me to remove the head - I wanted to do compression test before pulling head to make sure my only issue was the oil leaking out of front side of head.
I discovered I could not put my socket on #2 cyl injector - the aneroid (space ship) on the NA pump is in the way
So - how have any of you dealt with this? I'm not sure that I could even get a box end wrench on that thing even with the lines off the car.
(life must move on - I pulled the head without doing my comp test - oh well....)
The fleet
92 eco diesel (my driver turned project)
94 suburban (mine)
69 Chevelle 327 w/hillborn - resting nicely
89 Jetta coupe (sons 16v ABA head swap w/turbo and megasquirt - not run yet)
2000 jetta (other sons)
98 jetta (daughters)
2001 jetta tdi (girlfriends)
03 subaru outback (girlfrie
November 14, 2012, 11:38:42 am
Re: injector removal problem when car has N/A pump?
November 14, 2012, 11:38:42 am »
You could have tried loosening the pump and pulling it all the way away from the engine. Not sure if it would have been enough or not though.
November 14, 2012, 04:26:41 pm
Re: Re: injector removal problem when car has N/A pump?
November 14, 2012, 04:26:41 pm »
On mine I can just slip the socket over the injector and THEN connect the extension. No way I can get it on with the extension attached due to interference with my LDA.
Sent from my HTC One X using Tapatalk 2
November 14, 2012, 04:50:00 pm
audilvr
November 14, 2012, 04:50:00 pm »
the socket we use at the shop i work at is ground to a taper to fit.
November 14, 2012, 05:26:48 pm
derekp
November 14, 2012, 05:26:48 pm »
can you guys tell me - 3/8 or 1/2 inch drive socket and what the overall length of the socket you use?
Appreciate it - I only have 1/2 inch drive socket no way will it fit at all.
thanks.
The fleet
94 suburban (mine)
November 14, 2012, 08:33:47 pm
November 14, 2012, 08:33:47 pm »
I have one car with the turbo version (LDA) and one with the altitude version (ADA). (The other cars have the lower IP covers.)
I use a MiT 1/2" drive deep impact socket. The socket is probably ~80MM tall and 34mm wide. It just barely fits in the injector-well .
I mark the pump position and turn the top as far from the valve-cover as it will go.
November 14, 2012, 08:34:47 pm
Moderator
4552
November 14, 2012, 08:34:47 pm »
Get an adapter that goes from 3/8ths to 1/2 inch and use the 3/8th extension. Adapters go both ways. I use them all the time but mostly to reduce from larger size but on occasion it helps to go the other way. As in this case.
November 14, 2012, 09:08:48 pm
92EcoDiesel Jetta
November 14, 2012, 09:08:48 pm »
Impact sockets are thicker wall so don't use it if space is tight. (ask me how I know) Since getting a 12 point 27 mm deep socket that's much thinner wall than the impact (from Lowes) no more clearance isaues.
