Author Topic: Vacuum Pump (rotary, vane) o-rings: Where to buy?  (Read 5786 times)
November 13, 2012, 02:58:32 pm
« on: November 13, 2012, 02:58:32 pm »
Anyone got a line on the o-rings for the newer style vacuum pump? (AutohausAZ & PartsPlace don't seem to stock em.)
Reply #1November 13, 2012, 03:16:49 pm
jseeley
  • 106
Re: Vacuum Pump (rotary, vane) o-rings: Where to buy?
« Reply #1 on: November 13, 2012, 03:16:49 pm »
I used a distributor o-ring (my assumption was that it's the same)  ???
85 Golf Diesel 1.6 NA 240K miles? (odometer broken)
87 Cabriolet 1.8 Gasser 104K miles
05 Golf 2.0 Gasser 66k miles
03 Jetta Wagon TDI 112k Miles
Reply #2November 13, 2012, 03:55:18 pm
« Reply #2 on: November 13, 2012, 03:55:18 pm »
Which one? the one inside the gear is dealer, the one one the pump cover is the same as the IM shaft seal carrier o ring, and the one that seals to the block I think is dealer or the same as the distributer if it worked for the guy above.
Reply #3November 13, 2012, 06:10:22 pm
Dakotakid
  • 1240
« Reply #3 on: November 13, 2012, 06:10:22 pm »
Have you ever heard of an industrial hydraulic supply store?
.....there you go......
Reply #4November 13, 2012, 06:45:07 pm
« Reply #4 on: November 13, 2012, 06:45:07 pm »
Thanks for the replies.
Autohaus has the larger "distributor oil seal".  Looks like the dealer for the inner ring.
Reply #5November 13, 2012, 07:30:07 pm
92EcoDiesel Jetta
« Reply #5 on: November 13, 2012, 07:30:07 pm »
Dealer wanted $6 for the vac pump to block o-ring what a rip off! I looked in my box of o-rings and found that the one for the coolant flange on the cyl head fits perfectly.
Reply #6November 13, 2012, 08:28:28 pm
« Reply #6 on: November 13, 2012, 08:28:28 pm »
Sweet. Thanks!
Reply #7December 15, 2012, 06:34:17 am
« Reply #7 on: December 15, 2012, 06:34:17 am »
Followup:
The water flange o-ring fits nicely, on the flange/block area. P/N 037 121 687
The shaft seal from dealer: P/N 068 145 117 B
(The distributor o-ring was too small.)
Reply #8December 15, 2012, 08:55:13 am
« Reply #8 on: December 15, 2012, 08:55:13 am »
The distributor o-ring is the correct VW part. 068145119.
Reply #9December 15, 2012, 09:25:32 am
« Reply #9 on: December 15, 2012, 09:25:32 am »
Thanks, I got the wrong distributor o-ring. (026 905 261)
Reply #10December 16, 2012, 07:04:53 am
« Reply #10 on: December 16, 2012, 07:04:53 am »
Anyone know anything about the bushing
Reply #11December 16, 2012, 07:14:23 am
« Reply #11 on: December 16, 2012, 07:14:23 am »
Bushing was dealer only and NLA.
Reply #12December 16, 2012, 07:42:24 pm
« Reply #12 on: December 16, 2012, 07:42:24 pm »
Seriously, though, if you can find an industrial hardware store in your area, it's worth an occasional trip there. The one near me has a great supply of metric fasteners, miscellaneous hose, rubber parts and o-rings that start at maybe 1/16" diameter up to what have to be several meters in circumference.
Reply #13December 16, 2012, 07:59:15 pm
« Reply #13 on: December 16, 2012, 07:59:15 pm »
Ja, no doubt.
It would be nice to find the shaft seal from a 3rd party. $6 for that little dude is steep, IMO.
As an aside:
I spun the IM shaft CCW with a drill, to pump some oil around. Nice to see the air getting purged out the lifter bores.  It's also kind of surprising how loud the vacuum pump is when you can hear it through the open oil returns in the head: POP POP POP POP...  It seems like a fair amount of oil gets pushed through, while pushing out the vanes.
Reply #14December 16, 2012, 07:59:43 pm
« Reply #14 on: December 16, 2012, 07:59:43 pm »
I should qualify...my dealer said NLA, so they still could be, but for sure custom made or dealer item only.
