S-PAutomotive.com
Author Topic: Motor mounts  (Read 5997 times)
Reply #30December 09, 2012, 09:42:31 pm
bbob203
  • 1789
Re: Motor mounts
« Reply #30 on: December 09, 2012, 09:42:31 pm »
This could be an upgrade on mk2's no? http://www.germanautoparts.com/productdisplay/56841
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #31December 10, 2012, 09:00:25 am
  • 1508
Re: Motor mounts
« Reply #31 on: December 10, 2012, 09:00:25 am »
That hydro passenger mount might require a different bracket on the engine.
(If anyone has that bracket, or its part number, I'm interested.)
Reply #32December 10, 2012, 09:23:32 am
  • 7837
Re: Motor mounts
« Reply #32 on: December 10, 2012, 09:23:32 am »
From making the mounts myself for a flipped VNT for mk2 I found some things out. IIRC I think the differences are in the cast aluminum piece. The bolt holes are the same in all, but there is one that is about 7/16" longer than the other. FWIW I think you could get it to work no matter what you have, but the one that works I am pretty sure has an A at the end of the 9 digit part number.
Reply #33December 10, 2012, 09:39:35 am
  • 1508
Re: Motor mounts
« Reply #33 on: December 10, 2012, 09:39:35 am »
... I found some things out. IIRC I think the differences are in the cast aluminum piece. The bolt holes are the same in all, but there is one that is about 7/16" longer than the other....
Ja, I think Tylernt had an issue with his motor sitting a bit jakey after putting in the pass hydro last year. The 16V bracket may be a bit different.
Reply #34December 10, 2012, 10:00:59 am
  • 9005
Re: Motor mounts
« Reply #34 on: December 10, 2012, 10:00:59 am »
I think I read somewhere that the Passat engine sits at a different angle than the Golf/Jettas. I have no idea if it's true or not though.
