Author Topic: What gearbox to choose for idi engine?  (Read 5904 times)
November 03, 2012, 01:23:12 pm
A.Dutsov
« on: November 03, 2012, 01:23:12 pm »
I need gearbox with cables for my project, please give me advice for strong gearbox with cables, but the clutch to be with cable too ... i am looking at 02A from tdi engines, but all i sow are with clutch pump ... is there any chance to convert gearbox with clutch pump to clutch cable? if i dont find my answer, i will try to fit clutch master, but i dont have enough space, and i will have to rework the firewall alot to do this ...
Reply #1November 03, 2012, 04:22:10 pm
bbob203
  • 1789
Re: What gearbox to choose for idi engine?
« Reply #1 on: November 03, 2012, 04:22:10 pm »
you need cable and actuator from a 5 speed euro van. Go with a gearbox with similar gears to an
 A C N series tranmission inless you are cranking serious torque and hp the tdi trans will kinda suck.if its a 1.6
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #2November 03, 2012, 10:05:23 pm
A.Dutsov
« Reply #2 on: November 03, 2012, 10:05:23 pm »
1.9 aaz engine, but with alot of power planned, please some more info on the strong gearboxes ... what vans ... i am in europe, so its ok to be some euro spec van etc, just dont know whats strong and what not ...
Reply #3November 04, 2012, 03:32:52 am
bbob203
  • 1789
« Reply #3 on: November 04, 2012, 03:32:52 am »
well if its an aaz then I think you'll be ok with tdi transmission. as far as I can tell al 02a transmissions are about the same as far as strength when they are stock. if you are adventerous you could split the case pull out the diff and install an arp bolt kit on it to ensure that the stock rivets wont be a problem.
03 Jetta wagon TDi
Reply #4November 04, 2012, 10:18:52 am
« Reply #4 on: November 04, 2012, 10:18:52 am »
02A has much bigger gears and bearings inside...
the bearings (the small ones, from engine braking) are what i wear out the most.. ive been thru 6-7 020 trannies over the years..
the way i drive, it tears the bearings out of the transmixers, not the ring gear rivets..
02A is the way to go if you want big power.. (3-4x stock torque)
020 trannies are fine as long as they dont hook up.. once you start running sticky tires, or drag slicks, and doing hard launches, they grenade left and right...
if you got a light mk1, and you dont have alot of extra power, then stock 020 is fine, but if you got a mk2 w/ big power, or a mk3 with any power increase, then an 02A is a great idea..
Reply #5November 04, 2012, 10:25:11 am
A.Dutsov
« Reply #5 on: November 04, 2012, 10:25:11 am »
its fiat 126 rwd with aaz engine, but i will use drag slicks and maybe in future some NOS, i dont want to do it 2-3 times, i will do it once, i can find 02A gearbox, but now i sow i will have to find exactly from toledo or ibisa because the clutch with cable i want to stick with. Thanks to all for the pleasant info ... and i hope it helps someone else too ... also, whats the weak point of the 02A? gears are ok, what breaks in? i will use gt2260v from iveco dayli or some compound setup ... i am after at least 200 wheel horse power ... i will buy g60 flywheel, and 228mm clutch, so i want the gearbox to be strong ... i have 3 020 gearboxes, but i dont want to break gearbox, then to change all my setup again and to put 02A, so i will put 02A as beginning, and will sell my 3 020 gearboxes ;) No point to do it false when i can do it right from first time! :)
Reply #6November 04, 2012, 11:28:47 am
bbob203
  • 1789
« Reply #6 on: November 04, 2012, 11:28:47 am »
can i ask hour you run and 020 in a rwd car?
03 Jetta wagon TDi
Reply #7November 04, 2012, 11:30:20 am
A.Dutsov
« Reply #7 on: November 04, 2012, 11:30:20 am »
its easy, you put it behind your seat with the engine itself ;) Its fiat 126p ... the engine is behind your seat from factory, just cutting some rear seats, and install the bigger engine with gearbox ;)
Reply #8November 04, 2012, 11:33:27 am
bbob203
  • 1789
« Reply #8 on: November 04, 2012, 11:33:27 am »
 ;D PICS!
03 Jetta wagon TDi
Reply #9November 04, 2012, 11:35:55 am
A.Dutsov
« Reply #9 on: November 04, 2012, 11:35:55 am »
after i source all needed things, i will post pics in my thread in the idi section ... i dont want to post pics when i am in the middle of nowhere ... i want to finish the chassis, then i will sandblast it and then i will take pics ;)
Reply #10November 04, 2012, 04:28:56 pm
« Reply #10 on: November 04, 2012, 04:28:56 pm »
Very nice! Being that I think most of us on here don't know from experience what kind of car you are working with, in terms of weight and stuff.. Would you mind filling us in?
What kinda of engine and transmission were in it stock? and how did they do? With more variables we will be able to give a better idea of what should work out best for your specific application.
Also, WELCOME TO THE BOARD :)
Reply #11November 04, 2012, 11:54:40 pm
A.Dutsov
« Reply #11 on: November 04, 2012, 11:54:40 pm »
i will now answer you, then all questions about the car will be answered in the thread in th idi section ;) The car was 2 cilinder air cooled engine 600cc 22-3hp, its about 600kg stock, and its rear engine polish fiat. you can search google for fiat 126p, its 2.90m long and 1.20m wide, we have class diesel in bulgaria in the drag championship, and i prepare this car for there. i cutted the rear seats to make place for the diesel engine, and now i will make the cage and the engine frame, after i clean the mess in the garage, i will start taking photos .. but for now its too dirty to take photos ;)
Reply #12November 05, 2012, 03:10:32 am
rs899
  • 647
Reply #13November 05, 2012, 01:36:10 pm
« Reply #13 on: November 05, 2012, 01:36:10 pm »
That nutty Military guy we used to have on here (NintendoKD) wanted to take an MR2, and put a VW TD in it..
dont see why you couldnt use an 020 or 02A in the back of a car, and build yourself a set of axles to hook everything up...
Reply #14November 05, 2012, 02:01:30 pm
bbob203
  • 1789
« Reply #14 on: November 05, 2012, 02:01:30 pm »
i guess if 020 the shifter box would be backwards.
03 Jetta wagon TDi
