Author Topic: Has anyone seen this mess?  (Read 5174 times)
October 29, 2012, 10:46:40 pm
shwak23
  • 417
    • Blackdog Junkyard
« on: October 29, 2012, 10:46:40 pm »
Reply #1October 30, 2012, 02:10:07 am
Re: Has anyone seen this mess?
« Reply #1 on: October 30, 2012, 02:10:07 am »
Reply #2October 30, 2012, 07:28:47 am
« Reply #2 on: October 30, 2012, 07:28:47 am »
I don't see two pumps on the volvo.
Reply #3October 30, 2012, 11:41:42 am
« Reply #3 on: October 30, 2012, 11:41:42 am »
2 pumps, HOW THE F?!
and WHAT THE F?
double 2 cylinder pumps?
Reply #4October 30, 2012, 12:19:39 pm
« Reply #4 on: October 30, 2012, 12:19:39 pm »
Its chain drive  below the stock one...
You can see the injector lines are T'ed in the vid, but here's a  pic.
http://www.garaget.org/?car=165910&image=1572144
Double stock pumps, no breakey  drive shaft at high RPM, well not the pump drive one anyway.
« Last Edit: October 30, 2012, 12:21:10 pm by 745 turbogreasel »
Reply #5October 30, 2012, 12:26:35 pm
« Reply #5 on: October 30, 2012, 12:26:35 pm »
holy shizzz...
you in theory have 2x fueling with 2 pumps, at the same RPMs, right?
wouldnt it be pretty important to have both pumps tuned IDENTICAL?!
Reply #6October 30, 2012, 12:40:58 pm
rallydiesel
  • 1880
« Reply #6 on: October 30, 2012, 12:40:58 pm »
That's nuts. I've never seen anything like that with a VE pump. Anybody know where we could find more info on that one?
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #7October 30, 2012, 03:00:47 pm
smutts
  • 720
    ClackClackClackClackClack
« Reply #7 on: October 30, 2012, 03:00:47 pm »
All that smoke shouts that it doesn't burn too well. Drilling and tapping an extra injector into each of those combustion chambers must have been bit of a chore. What is the horsepower limit of a single VE pump? 25kw per pot? x4 pots, x1.34102209 for horsepower, gives 134 horses. Okay I see why they might try this. Heath Robinson and Rube Goldberg would be proud. ;D
Reply #8October 30, 2012, 03:04:10 pm
« Reply #8 on: October 30, 2012, 03:04:10 pm »
I don't think the timing  really does have to be spot-on, plenty of OEMs  use split shot injection.
There is no extra injector, just a T in the delivery pipe, and  delivery valves keep anything from  going the wrong way.
It also lets you get a ton of fuel without a big heavy  plunger that doesn't like High  RPM,  and a nice gentle camplate that won't skip as easy.
Makes sense, but seems like a lot of work  to get right.
Added bonus, limp home if a pump fails.
« Last Edit: October 30, 2012, 03:11:04 pm by 745 turbogreasel »
Reply #9October 30, 2012, 05:22:11 pm
bbob203
  • 1789
« Reply #9 on: October 30, 2012, 05:22:11 pm »
That was as much exhaust as everyone on the forum makes in one year.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #10October 30, 2012, 05:26:24 pm
« Reply #10 on: October 30, 2012, 05:26:24 pm »
nah, diesels make LOTS of exhaust..
that D24 was barely running.. i wasnt impressed.
Reply #11October 30, 2012, 06:23:49 pm
« Reply #11 on: October 30, 2012, 06:23:49 pm »
If my Swedish translator is right, it makes over 350HP.  Maybe not too surprising it's a bit cold blooded?.
Reply #12October 30, 2012, 06:26:53 pm
« Reply #12 on: October 30, 2012, 06:26:53 pm »
The VW one had two sets of injectors.
Reply #13October 30, 2012, 07:12:38 pm
« Reply #13 on: October 30, 2012, 07:12:38 pm »
So it does, must be a long tunnel to the combustion chamber.
Here's a twin pump 6.5 setup https://www.youtube.com/watch?v=FwFWNReCmck
Reply #14October 30, 2012, 09:40:42 pm
MJF
  • 581
« Reply #14 on: October 30, 2012, 09:40:42 pm »
« Last Edit: October 30, 2012, 09:42:30 pm by MJF »
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
