Author Topic: b3 passat wagon 16v to MTDI swap *Glow plug wiring time*  (Read 31805 times)
Reply #45October 31, 2012, 04:47:24 am
bbob203
  • 1789
Re: b3 passat wagon 16v to MTDI swap.
« Reply #45 on: October 31, 2012, 04:47:24 am »
the reason I said that is to accommodate the sensor that is there on the 1.6 but maybe that one isn't needed? Whats its purpose on the 1.6?
So the glowplugs on that flange enchance the interior heat?
« Last Edit: October 31, 2012, 11:42:56 am by bbob203 »
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #46October 31, 2012, 01:01:21 pm
« Reply #46 on: October 31, 2012, 01:01:21 pm »
they dont really do a whole lot of anything, besides eat power..
Reply #47October 31, 2012, 03:08:59 pm
  • 3416
« Reply #47 on: October 31, 2012, 03:08:59 pm »
Yes, they enhance interior heat by adding a minuscule amount of heat to the coolant, but more importantly robbing power.  By increasing the load on the engine it warms up faster.  If you don't mind taking 15 minutes for decent cabin heat, then leave them off.
Reply #48October 31, 2012, 03:11:23 pm
« Reply #48 on: October 31, 2012, 03:11:23 pm »
lol, never thought about the added load to the engine, by way of the alternator..
Reply #49October 31, 2012, 03:29:19 pm
bbob203
  • 1789
« Reply #49 on: October 31, 2012, 03:29:19 pm »
will a b4 bentley have most of the info I need for the tdi motor and the b3 car?
03 Jetta wagon TDi
Reply #50October 31, 2012, 04:30:01 pm
  • 9005
« Reply #50 on: October 31, 2012, 04:30:01 pm »
The B4 Bentley is 2 huge books. It doesn't specifically cover the B3, but they are very similar. Since you are going mTDI, if you know your way around the IDIs the engine really isn't anything special. You could even get the MK3 Bentley covering the TDI. It would likely cost less than the Passat version.
This old WTB ad might be of some help
http://www.vwdiesel.net/forum/index.php?topic=31583.0
Reply #51October 31, 2012, 06:41:51 pm
bbob203
  • 1789
« Reply #51 on: October 31, 2012, 06:41:51 pm »
Essentialy the only things wiring wise I need to hook up to the tdi is the 4 pin coolant sensor for the fan, the alternator, stop solenoid and starter stuff? glowplugs optional.
03 Jetta wagon TDi
Reply #52October 31, 2012, 11:36:37 pm
« Reply #52 on: October 31, 2012, 11:36:37 pm »
b3 like mk2... fan sensor on rad... o 4 pn req... that coolent gauge and comp temp sensor....
Reply #53November 01, 2012, 08:12:54 am
bbob203
  • 1789
« Reply #53 on: November 01, 2012, 08:12:54 am »
computer temp sensor?
So all i really need there is a 2 pin for the temp guage?
Also do i have to take off the black cover on the alt to get to the w terminal?
is all the wiring for the injection system and other computer related crap pretty easy to remove? is it all bundled together pretty well? i saw that it had some sort of wiring harness running up under the back seat.
03 Jetta wagon TDi
Reply #54November 01, 2012, 10:43:51 am
  • 9005
« Reply #54 on: November 01, 2012, 10:43:51 am »
That's for the tranny's computer.
Reply #55November 03, 2012, 07:24:26 am
bbob203
  • 1789
« Reply #55 on: November 03, 2012, 07:24:26 am »
will any dakota digital converters work to drive a gasser tach with the cps sensor on the tdi?
03 Jetta wagon TDi
Reply #56November 03, 2012, 12:55:54 pm
  • 3416
« Reply #56 on: November 03, 2012, 12:55:54 pm »
The crank position sensor gives 4 pulses per rev.  I've been planning on using a flip flop circuit to cut that signal in half and drive a gas tach.  That signal would already be correct for any 8 cylinder 4-stroke tach.
Reply #57November 03, 2012, 01:48:26 pm
bbob203
  • 1789
« Reply #57 on: November 03, 2012, 01:48:26 pm »
looks like this one would do the trick.
http://www.dakotadigital.com/index.cfm/page/ptype=product/product_id=127/category_id=287/home_id=59/mode=prod/prd127.htm
03 Jetta wagon TDi
Reply #58November 03, 2012, 01:52:31 pm
bbob203
  • 1789
« Reply #58 on: November 03, 2012, 01:52:31 pm »
will the speedo be cable driven on the auto cluster on the b3 im using?
03 Jetta wagon TDi
Reply #59November 03, 2012, 10:29:48 pm
  • 9005
« Reply #59 on: November 03, 2012, 10:29:48 pm »
This is what I'm doing for a tach signal
http://www.vwdiesel.net/forum/index.php?topic=30442.0
Fixmyvw.com
