Author Topic: b3 passat wagon 16v to MTDI swap *Glow plug wiring time*  (Read 70104 times)
October 21, 2012, 06:04:27 am
bbob203
  • 1789
« on: October 21, 2012, 06:04:27 am »
I have been planning this project for awhile now and I'm finally starting to get the parts together. This will be my place to post my progress ask questions and display picturres I may snap along the way. My goal for this car is a long haul car for doing cross country driving loaded up with a top cap for cargo and the back end setup with a mattress for sleeping.
Here's a list of what a plan on putting in the car..
1z motor out of 96 passat with libbydiesel mtdi pump
02a ctn tdi trans $550 3.15 r&p. .75 but I plan on using a. 68 if I can get one.
might go with a corado clutch
Here are some pics of the motor 230,xxx well maintained southern motor $1000
« Last Edit: September 24, 2013, 11:10:45 am by bbob203 »
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #1October 21, 2012, 06:24:32 am
Re: b3 passat wagon 16v to MTDI swap.
« Reply #1 on: October 21, 2012, 06:24:32 am »
Question: passats are already hydro clutch right?
Reply #2October 21, 2012, 06:27:20 am
bbob203
  • 1789
« Reply #2 on: October 21, 2012, 06:27:20 am »
they are but I'm buying the car empty with no engine or transmission parts. cable clutch more reliable to me.
03 Jetta wagon TDi
Reply #3October 21, 2012, 08:22:25 am
CrazyAndy
  • 739
« Reply #3 on: October 21, 2012, 08:22:25 am »
You know what to get for the cable conversion?  I have all the parts and can give you the PN's.   Also, the cable is NLA, so use a 1991 CRX cable;  I know it's long but you can loop it around the engine bay a bit.
EDIT:  The cable was advised for putting an 02A into a MK1, but it might still work which is why I suggested it.
Reply #4October 21, 2012, 08:41:43 am
bbob203
  • 1789
« Reply #4 on: October 21, 2012, 08:41:43 am »
I was gonna get this kit
 http://euro-wise.com/store/index.php?main_page=product_info&products_id=336
03 Jetta wagon TDi
Reply #5October 21, 2012, 12:41:11 pm
danster
  • 71
« Reply #5 on: October 21, 2012, 12:41:11 pm »
It might be an idea to block off the EGR pipe now. Even with the engine being low miles you could pull the inlet manifold and check for crud build up in the ports. It's far easier to clean out any build up with the engine on the floor than it is when the engine is in the bay.
The 02A cable clutch conversion parts will be more expensive than finding a decent slave cylinder and pipework. The hydro clutch setups are really not that unreliable. Is the pedal box still fitted to the car with clutch master cylinder?
Reply #6October 21, 2012, 12:44:45 pm
bbob203
  • 1789
« Reply #6 on: October 21, 2012, 12:44:45 pm »
I guess I would have to swap out the pedal cluster to. but I think dude is taking all clutch stuff with trans.
03 Jetta wagon TDi
Reply #7October 21, 2012, 03:35:04 pm
bbob203
  • 1789
« Reply #7 on: October 21, 2012, 03:35:04 pm »
Definitely going to do that.
03 Jetta wagon TDi
Reply #8October 22, 2012, 09:40:45 am
« Reply #8 on: October 22, 2012, 09:40:45 am »
if he no take pedals.. keep hydro... the lines between master and slave is 6mm brake line.. can build your own if you had too.. a 6mm flex line, 2 pieces of preflared steel lines.. bolt together.. done... how i extended my hydro line stuff in the kubvan...
glad on 02a...
think of intercooler where at... tons of room under hood.. but front air.. not so much...
Reply #9October 24, 2012, 06:04:44 am
bbob203
  • 1789
« Reply #9 on: October 24, 2012, 06:04:44 am »
What about ac lines? will they need to be custom?
03 Jetta wagon TDi
Reply #10October 24, 2012, 06:33:15 am
« Reply #10 on: October 24, 2012, 06:33:15 am »
16v lines no fit tdi compressor... so yea custom unless you want v belts, then mk1/mk2 diesel w ac fits the stock ac lines..
Reply #11October 24, 2012, 06:35:26 am
bbob203
  • 1789
« Reply #11 on: October 24, 2012, 06:35:26 am »
That might be a project for a later date. A/c isn't super important but not way id voluntarily go back to belts to have it.
Im dead set on doing the tdi i have a 600 deposit on the motor picking it up monday.
« Last Edit: October 24, 2012, 06:37:05 am by bbob203 »
03 Jetta wagon TDi
Reply #12October 24, 2012, 07:24:39 am
bbob203
  • 1789
« Reply #12 on: October 24, 2012, 07:24:39 am »
What do about tank sending unit. Have read ideas before but cant find anymore? Take out guts in gas one?
03 Jetta wagon TDi
Reply #13October 24, 2012, 08:02:02 am
« Reply #13 on: October 24, 2012, 08:02:02 am »
cause u asked on poortex... :P
guts modded or passat tdi wagon, 96-97 supposedly fits...
u need to see what vr6 ac lines like... may be able to retro fit them in.. but 1st figure out if comps/fittings same ;)
Reply #14October 24, 2012, 08:05:27 am
bbob203
  • 1789
« Reply #14 on: October 24, 2012, 08:05:27 am »
Could i put the ac clutch pulley from the tdi compressor on a 1.6 compressor?
03 Jetta wagon TDi
