Author Topic: Quieting the IP  (Read 4281 times)
October 19, 2012, 04:45:43 pm
Syncroincity
  • 727
Quieting the IP
« on: October 19, 2012, 04:45:43 pm »
My Giles pump is loud... embarassingly so, particularly in the concrete canyons here where the clack echoes from all directions.
I seem to recall this might be a timing issue? I set the pump to 1.0mm, which way (towards or away from the head) should I bump the pump a bit to reduce injection noise?
JC McCavitt
'86 Syncro GL Camper AAZ
'98 Jetta Wolfie
Reply #1October 19, 2012, 04:47:22 pm
Re: Quieting the IP
« Reply #1 on: October 19, 2012, 04:47:22 pm »
Away.
Reply #2October 19, 2012, 04:49:48 pm
Syncroincity
  • 727
Re: Quieting the IP
« Reply #2 on: October 19, 2012, 04:49:48 pm »
Gracias.  :)
JC McCavitt
'98 Jetta Wolfie
Reply #3October 19, 2012, 05:01:40 pm
Re: Quieting the IP
« Reply #3 on: October 19, 2012, 05:01:40 pm »
your PUMP is loud?!
Reply #4October 19, 2012, 05:34:07 pm
Re: Quieting the IP
« Reply #4 on: October 19, 2012, 05:34:07 pm »
IIRC Giles told me to time no higher than .95mm. It is probably different for every pump he builds but it is something to think about.
Reply #5October 19, 2012, 06:17:22 pm
Re: Quieting the IP
« Reply #5 on: October 19, 2012, 06:17:22 pm »
Yes the pumps are physically loud, there is quite a bit going on inside them ;)
But it is not the pump that you hear clacking away, it is your WAY to advanced timing lol. Fall back to like .90 or .95mm
Reply #6October 19, 2012, 08:09:16 pm
Syncroincity
  • 727
Re: Quieting the IP
« Reply #6 on: October 19, 2012, 08:09:16 pm »
your PUMP is loud?!
...OK, the pump is making the motor loud, LOL
JC McCavitt
'98 Jetta Wolfie
