Author Topic: Vacuum pump upgrade  (Read 3944 times)
October 15, 2012, 09:30:09 pm
ToddA1
  • 434
Vacuum pump upgrade
« on: October 15, 2012, 09:30:09 pm »
I grabbed a vane pump from a 83 Rabbit, in the junkyard today. I'm guessing this wasn't the original pump.
I plan on putting this into my 81, but is it safe to just cap the breather port on the block or should I run a tee from the block to the pump, then to the booster? My rotary pump had 2 ports but the vane pump only has 1, and is only connected to the booster.
I notice the later 90s TDIs don't vent the block.
-Todd
Reply #1October 16, 2012, 09:38:11 am
Re: Vacuum pump upgrade
« Reply #1 on: October 16, 2012, 09:38:11 am »
i think 83 was the switch over year, my 83 had the vane pump.  run the port on the vacuum pump to the booster, the opening in the block you can cap off, or what i recommened is to run a hose from it and T it into the valve cover breather, this solved blow by issues on my 83 rabbit.
Reply #2October 16, 2012, 02:28:41 pm
ToddA1
  • 434
« Reply #2 on: October 16, 2012, 02:28:41 pm »
Easy enough.  Thanks!
-Todd
Reply #3October 16, 2012, 02:35:20 pm
« Reply #3 on: October 16, 2012, 02:35:20 pm »
Just be sure you understand what Trev was saying.  Tee the block port into the crank vent, not the hose from the vac pump to booster.
Reply #4October 16, 2012, 03:27:25 pm
« Reply #4 on: October 16, 2012, 03:27:25 pm »
Haha right!
Reply #5October 16, 2012, 04:10:45 pm
« Reply #5 on: October 16, 2012, 04:10:45 pm »
that was how the factory hose was routed..
from the block to the VC to the intake..
