Author Topic: TDI block heater  (Read 17107 times)
October 07, 2012, 03:41:21 pm
TDI block heater
« on: October 07, 2012, 03:41:21 pm »
http://www.jcwhitney.com/tank-type-engine-heaters/p2000837.jcwx?skuId=206196&filterid=c1648u0j1
I am thinking of doing this instead of a normal block heater in my TDI. Do any of you run these? If so do you notice a difference in cooling or is it fine to leave in all year? Also, if you run one, does it do a good job of heating? My TDI starts whenever, it just takes 25 minutes to have really good heat and maybe 10 to have noticable heat when it is really cold.
Reply #1October 07, 2012, 04:16:50 pm
Re: TDI block heater
« Reply #1 on: October 07, 2012, 04:16:50 pm »
Why would you prefer that over a freeze plug style?
I totally understand wanting better heat.  My two complaints about my mTDI are that it's too efficient (it takes a LONG time for heat in cold weather) and it's too powerful (it makes my clutch slip).
Reply #2October 07, 2012, 04:54:43 pm
« Reply #2 on: October 07, 2012, 04:54:43 pm »
Mainly for the convienience of the install.
Reply #3October 07, 2012, 05:19:16 pm
« Reply #3 on: October 07, 2012, 05:19:16 pm »
i had the freeze plug style, it definitely made starting in the cold easier but it didn't seem to actually make anything hot or noticebly warm faster
Reply #4October 07, 2012, 05:36:07 pm
« Reply #4 on: October 07, 2012, 05:36:07 pm »
In the 1.6 I had it made heat TONS faster, also felt like the engine was "free" .
The TDI I could let idle for years and it would never heat up much. I just figured this other style would be easier to plumb in.
Reply #5October 07, 2012, 07:06:49 pm
  • 1739
« Reply #5 on: October 07, 2012, 07:06:49 pm »
Be careful of poor quality freeze plug insert block heaters. Seen many pop out. The only ones we would install were the ones that came through VW. They were made in Canada, I wish we could have seen who made them
Reply #6October 07, 2012, 09:24:13 pm
« Reply #6 on: October 07, 2012, 09:24:13 pm »
It was about.. 32F here today, and I drove my mtdi around for a good half hour in town.. and just.. JUST made it to operating temperatures. I am afraid for winter. I really am.
Reply #7October 08, 2012, 03:01:40 pm
rbremiller
  • 69
« Reply #7 on: October 08, 2012, 03:01:40 pm »
       I concur with "the caveman" use only a high quality heater. I've had very good success using Kats block heaters http://www.fivestarmanufacturing.com/Kat_s in my VW's for 20 + years. My '99.5 Jetta doesn't need one and we've had a few mild winters lately but I remember plugging that heater in @ 0º up on the mountain I lived on and in 20 minutes the top hose was warm. I think the block heater has better heat transfer as the heat goes straight up into the head. I've been considering a block heater for my mTDI (first winter) in addition to relayed coolant glow plugs; 2 on 1 relay and 1 on the other. Have you considered the CGP's for heat?
Rich B
'91 180k Audi 80Q mTDI DD AHU, K14, LT pump,
http://www.motorgeek.com/viewtopic.php?t=45645
'99 Jetta TDI 204k '02 engine, RC3+E, 11mm IP, .216, Racepipe, 2.5''SS exhaust, PD Lift pump,  Boostvalve, PanzerPlate, boost gauge, MAF delete.
'89 Audi 80Q ...waiting
'85 BMW R80
Reply #8October 08, 2012, 04:21:10 pm
« Reply #8 on: October 08, 2012, 04:21:10 pm »
I was gonna consider hooking up the CGP's on my mtdi for this first winter with it.
I didnt need glowplugs even at the tail end of last winter (when i did the swap) and it was still -20c.
Reply #9October 08, 2012, 04:41:02 pm
« Reply #9 on: October 08, 2012, 04:41:02 pm »
Come to think of it I may have had a stuck open thermostat at the time,
Which is why I did this, the mannequin was for the lolz
Reply #10October 10, 2012, 03:45:35 pm
« Reply #10 on: October 10, 2012, 03:45:35 pm »
NICE! Reminds me of the old days when I would drive around with "inflate a date" buckled into the passenger side of my truck.
Well, I just found this out by asking a garage and Lord Verminaard about the ALH block. The garage said that there was something difficult and they couldn't remember but it wasn't possible to put the freeze plug style in economically. I asked Lord V if the ALH even had freeze plugs on the back of the engine and he said his does not. I couldn't see any on mine and thought it may require removal of the turbo, but I guess not. Here is reason #2 I won't put the freeze plug style in.
Reply #11October 10, 2012, 06:21:42 pm
« Reply #11 on: October 10, 2012, 06:21:42 pm »
That's a good reason.  Yup, I just went and looked at one of my ALH engines and sue enough, no freeze plugs.  I haven't rebuilt one yet, so I hadn't noticed the lack.
Reply #12October 15, 2012, 09:45:57 am
« Reply #12 on: October 15, 2012, 09:45:57 am »
the frost heater part of that post was the only thing i really cared about..
happy tho? i took it off for you ;)
Reply #13October 15, 2012, 03:49:44 pm
« Reply #13 on: October 15, 2012, 03:49:44 pm »
But then added it back ;) lol
Reply #14October 20, 2012, 06:36:12 pm
madrogers
  • 165
« Reply #14 on: October 20, 2012, 06:36:12 pm »
Up here in winnipeg it gets cold and the glue on oil pan heater the dealer put on when we bought the car just did not cut it. I found a strap on heater ( dont laught) . it is an oil pan heater basicly, it is a 300 watt element that has a tin cover on the back of it with a stud sticking out the clover , i made a littel braket and attached it agaist the block beside the turbo ( there is the only open  space to get somthing against the block ) run the wire and it works great, i can e-mail a pic if you would like, would like to post a pic but cann"t figger out how to do this on this board .
83 CADDY 1.6 TD WINTER
83 CADDY 1.9 AAZ SUMMER
