Author Topic: 020 transmission tear-down (5th gear swap)  (Read 9205 times)
February 22, 2006, 05:21:48 am
BlackTieTD
  • 1512
« on: February 22, 2006, 05:21:48 am »
http://www.thediygroup.com/020teardown.htm
http://scirocco.dhs.org/cheapassron/020tranny/index.htm
two good links for any of you guys wanting to tear into your 020s or go to a longer 5th.  :)
Reply #1February 22, 2006, 05:35:27 am
Northboundtrain
  • 131
    • http://boulderbiodiesel.com
« Reply #1 on: February 22, 2006, 05:35:27 am »
Very cool.  I can see that there are a lot of specialized tools necessary to teardown and rebuild a tranny.  What would a tranny shop typically charge to install a longer 5th gear or final drive ratio?
I just got back from a 1,500 mile road trip with the Jetta.  I was pushing it pretty hard, trying to maintain between 75 and 80 mph, and it revs pretty high at that speed.  Fuel economy drops way off.  When I have the tranny out for the new engine install in a few weeks, I might like to change the gearing too.
'75 Chevy 3/4 ton 6.5L conversion
'91 Jetta 1.6L NA
Biodiesel
"The fool who persists in his folly will become wise." -Blake
Reply #2February 22, 2006, 05:38:10 am
BlackTieTD
  • 1512
« Reply #2 on: February 22, 2006, 05:38:10 am »
first step would be finding out the transmission code so you know what gears you have in the car. if you already have a .75 or .71 and a long final you won't be able to do much better without taller tires. if you have a shorter 5th... start looking for someone selling a .71 for a good price. i don't know of a shop to recommend.
Reply #3February 22, 2006, 04:19:43 pm
chrissev
  • 694
« Reply #3 on: February 22, 2006, 04:19:43 pm »
Quote from: "BlackTieTD"
Nice, thanks for the info.  Now I need to figure out if a 0.68 fifth out of a fox transmission would slide onto an 020.  The junkyards around here are full of old foxes, and no one cares what I take from them (I can rip the engines and transmissions apart and take little bits and pieces,no one at the parts yards give a s*&^ as long as I pay for what I take).
Reply #4March 06, 2006, 11:51:49 am
addautomotive
« Reply #4 on: March 06, 2006, 11:51:49 am »
WOW! That first link is fantastic! I wish I'd known about that when I replaced my reverse last year!
I'll post some pics of my homemade "specialized" tools.
Reply #5March 08, 2006, 06:02:37 am
addautomotive
« Reply #5 on: March 08, 2006, 06:02:37 am »
5th gear tool: (made from a 12mm socket)
case splitter: (had the guys at crappy tire weld this up for free. Yes, you read that right... for FREE)
Reply #6March 08, 2006, 09:49:48 am
addautomotive
« Reply #6 on: March 08, 2006, 09:49:48 am »
FWIW, I've done the 5th gear swap 3 times, and each time I did it with the transmission in the car.
Took me about 4 hrs the first time, can do it in about 2 hrs now. Not a bad job at all, and depending on the ratio change it can make a huge difference.
There's a ratio calculator on those links BlackTieTD posted.
Reply #7August 15, 2006, 08:23:19 am
lusob
  • 9
« Reply #7 on: August 15, 2006, 08:23:19 am »
Hi,
I have in my Golf 2 with SB engine gearbox 4T. From what gearbox can I take a 5th gear? My 5th gear is 0,745098. I read here about 0,684, but I don't know in what gearbox is this gear? Can you tell me a code of it? Are in 020 gearboxes better ratios and in which gearboxes, than 0,684?
