Author Topic: to retorque,or not to retorque  (Read 10510 times)
Reply #15June 22, 2006, 02:08:02 pm
RabbitGTDguy
  • 1274
« Reply #15 on: June 22, 2006, 02:08:02 pm »
Isn't that what I was getting at saying initially that it was removed to provide a couple of benefits?
1. To reduce the potential hot spots and cracking at this point where the piston is most vunerable
2. To reduce CR effectively without harming the squish volume like so many tend to do with stacking head gaskets...
Oye...another post though.
I'd said for safety's sake, it wouldn't hurt to check. I know I will be checking mine again once I have some miles on it. Heed Jake's advice though... but since your running normal dino still at this point the normal torque specs as per raceware's instructions will be honored...
Joe
1972 VW Westfalia
Reply #16June 22, 2006, 02:38:01 pm
vwmike
  • 1158
« Reply #16 on: June 22, 2006, 02:38:01 pm »
Quote from: RabbitGTDguy
I saw you talked about hot spots but I didn't see anything about stress risers  :D
Regardless, I see your point. I'll probably give it some consideration later. It would be easy enough to do....just be sure to cc it when you're done to ensure even combustion chamber volume.  8)
Reply #17June 22, 2006, 03:58:28 pm
RabbitGTDguy
  • 1274
« Reply #17 on: June 22, 2006, 03:58:28 pm »
They were done on a CNC lathe perfectly... I believe they CC'd at 29cc each. I was looking for a stock bowl CC measurement but don't believe anyone ever got one. I had the specs from before I machined but lost it on my other computer that crashed shortly after and didn't write it down anywhere else.
Joe
1972 VW Westfalia
Reply #18June 22, 2006, 11:29:17 pm
nkb
  • 154
« Reply #18 on: June 22, 2006, 11:29:17 pm »
i can cc mine, i still have my engine apart right now..
2004 Jetta TDI
1997 GMC Suburban 6.5td
2002 S-10 AWD V8 turbo, Sy-clone
1986 S-10 LT1
Reply #19June 23, 2006, 04:21:12 am
RabbitGTDguy
  • 1274
« Reply #19 on: June 23, 2006, 04:21:12 am »
that'd be great to have a comparison number. I'd appreciate the info after you have done it if you don't mind. Damn computers...since then, its always been...keep a hard copy
Joe
1972 VW Westfalia
Reply #20June 29, 2006, 09:51:53 pm
hillfolk'r
  • 1532
« Reply #20 on: June 29, 2006, 09:51:53 pm »
what did everyone die? almost a week with no posts in the tdi section,did ya see my post over on the tex about your exhaust joe??
mines running ok,how about you guys,i guess they are runnin too good,cause you must be out driving them,you have no time to post,right??  :wink:
Throttle cables ftw
