Author Topic: UPDATE na-td motor swap Timed correctly atf in now engine no crank  (Read 39481 times)
Reply #30September 28, 2012, 01:45:38 pm
bbob203
  • 1789
Re: UPDATE na-td motor swap few questions cranking but no fuel at injectors..
« Reply #30 on: September 28, 2012, 01:45:38 pm »
if you added the mk1 filter check there. I would suspect anything you have done to be causing the problem. Plus the MK2 inner fuel line doesn't like to mix with the barbs.
I replaced the black stuff with poly between filter and hard lines coming from under car.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #31September 28, 2012, 01:47:18 pm
bbob203
  • 1789
« Reply #31 on: September 28, 2012, 01:47:18 pm »
I might just try the mr gasket pump if it breaks ill take it back and get a refund. diesel shop wants over 100 bucks for one and its 3 days out.
03 Jetta wagon TDi
Reply #32September 30, 2012, 07:10:28 am
bbob203
  • 1789
« Reply #32 on: September 30, 2012, 07:10:28 am »
haven't had any time to mess with it past few days. picked up one of these http://www.aircraftspruce.com/catalog/eppages/solidstatepump.php?clickkey=7286
considering relocating my fuel filter back to where the water seperator used to be to save some room under hood. right after the lift pump.
03 Jetta wagon TDi
Reply #33October 01, 2012, 10:12:59 am
bbob203
  • 1789
« Reply #33 on: October 01, 2012, 10:12:59 am »
I've got it on iv I made with an 8 dollar aftermarket coolant reservoir hanging from hood above ip. I've pulled fuel thru ip with a vacuum pump a quart jar is half full of outbound fuel. I've been cranking and cranking. increased fuel screw. I'm so out of ideas. still don't think anything has come out of delivery valves.
03 Jetta wagon TDi
Reply #34October 01, 2012, 01:07:04 pm
bbob203
  • 1789
« Reply #34 on: October 01, 2012, 01:07:04 pm »
ip is not moving fuel when cranked. I lowered the fuel and raised the return jar and no fuel was going into it when I cranked.
03 Jetta wagon TDi
Reply #35October 01, 2012, 04:27:55 pm
srgtlord
  • 797
« Reply #35 on: October 01, 2012, 04:27:55 pm »
I would still install the inline electric pump, it will make your life alot easier.
Reply #36October 01, 2012, 06:32:30 pm
« Reply #36 on: October 01, 2012, 06:32:30 pm »
If the fuel is not moving when the engine is cranked, then the vane pump section of the injection pump is not working.
Reply #37October 01, 2012, 06:46:57 pm
bbob203
  • 1789
« Reply #37 on: October 01, 2012, 06:46:57 pm »
will having the pump to help move fuel mitigate this problem?
I'm just about to give up and put the eco pump back in I don't want to bit I'm so frustrated by this. I've installed pumps before and had no issues.
03 Jetta wagon TDi
Reply #38October 01, 2012, 08:31:14 pm
« Reply #38 on: October 01, 2012, 08:31:14 pm »
A lift pump might help.  If the vanes are temporarily stuck then a lift pump will let it run and might result in the vanes moving, but while the vanes are stuck there won't be any dynamic advance and it will be a dog.
Reply #39October 01, 2012, 08:51:19 pm
bbob203
  • 1789
« Reply #39 on: October 01, 2012, 08:51:19 pm »
I can only hope cuz I'm not getting a single drop of fuel at the delivery valves.
say I wanted to run an na pump from an early 80's 1.6 would it be better than running my eco pump?
03 Jetta wagon TDi
Reply #40October 02, 2012, 07:29:22 am
bbob203
  • 1789
« Reply #40 on: October 02, 2012, 07:29:22 am »
i cracked open the timing bolt and fuel came out also i hooked up the dial indicator and it shows the piston is moving. unfortunately i have cranked my battery to death so ill have to take to the parts store for a charge. im going to time my engine with the dial indicator but i have no clue how to read one of these things it is standard inches.
03 Jetta wagon TDi
Reply #41October 02, 2012, 09:08:56 am
« Reply #41 on: October 02, 2012, 09:08:56 am »
0.039" for inch.
Reply #42October 02, 2012, 09:30:59 am
« Reply #42 on: October 02, 2012, 09:30:59 am »
the actual PUMP portion (the portion under the pump top) is almost identical between the n/a and TD..
the ECO pump is much different tho.. and not capable of nearly as much fuel..
i would say the 1.6n/a pump would do better than the eco pump..
yes, do install a lift pump, they work wonders. every VW diesel should have one.
but, dont try and use the lift pump as the MAIN fuel pump. you still need the vane pump to work in the injection pump..
like andrew said, no timing advance and it will be a DOG.
you might even try and diesel-purge your pump thats on it, or dump it full of ATF, or something.. i imagine the vanes are just stuck..
did this engine sit for a long time with a dry pump?
Reply #43October 02, 2012, 11:59:31 am
bbob203
  • 1789
« Reply #43 on: October 02, 2012, 11:59:31 am »
sat about six months dry.
03 Jetta wagon TDi
Reply #44October 02, 2012, 12:10:30 pm
« Reply #44 on: October 02, 2012, 12:10:30 pm »
But with vaseline on everything. Alot on the vane pump
