Author Topic: FS: Diesel instrument cluster with tach  (Read 4873 times)
September 21, 2012, 06:40:34 pm
flowmastergfunk
  • 129
« on: September 21, 2012, 06:40:34 pm »
Bought it for my girlfriends car. Never put it in. Now she is an ex. Need's one wire repair where there was a bad splice before. I can do it before I send it unless you would like to do it yourself. The plastic is in really good shape but the glare doesn't make it look like it.
SOLD
« Last Edit: September 27, 2012, 06:02:53 pm by flowmastergfunk »
Reply #1September 22, 2012, 01:49:20 am
bbob203
  • 1789
Re: FS: Diesel instrument cluster with tach
« Reply #1 on: September 22, 2012, 01:49:20 am »
pmd. ce1 or ce2?
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #2September 22, 2012, 02:13:16 am
« Reply #2 on: September 22, 2012, 02:13:16 am »
ce1
Reply #3September 22, 2012, 02:23:52 am
bbob203
  • 1789
« Reply #3 on: September 22, 2012, 02:23:52 am »
03 Jetta wagon TDi
Reply #4September 22, 2012, 08:11:40 am
flowmastergfunk
  • 129
« Reply #4 on: September 22, 2012, 08:11:40 am »
Forgot too mention that! Sorry :(
I can get you some pigtails too if you feel like soldering! I believe that is possible...
« Last Edit: September 22, 2012, 08:15:03 am by flowmastergfunk »
Reply #5September 22, 2012, 09:37:37 am
« Reply #5 on: September 22, 2012, 09:37:37 am »
I'll take it if nobody has bought it and if everything works (if the clock doesn't work that's probably ok though).
I can possibly pick it up from you too so you don't have to ship it. I can solder it.
Reply #6September 22, 2012, 09:50:05 am
« Reply #6 on: September 22, 2012, 09:50:05 am »
quick easy tell if ce2 or older/other... shift light... ce2 never had them...
2nd tell on ce1 or ce2... ce2 has 1 plug... ce1/late westy (85-88) has 2 plugs..
the pcb/clock/everything but tach same as gasser... so easy fix/replacement...
fyi... this one is a direct fit into a vanagon tach cluster... just swap the tach out... did that for someone many years ago...
Reply #7September 22, 2012, 11:29:50 am
bbob203
  • 1789
« Reply #7 on: September 22, 2012, 11:29:50 am »
If someone could provide some more info on this Im not against it.
03 Jetta wagon TDi
Reply #8September 22, 2012, 01:26:45 pm
« Reply #8 on: September 22, 2012, 01:26:45 pm »
Just get a CE2 diesel cluster.. they were actually more common in my findings..
most of the ones i see are CE2 atleast..
Reply #9September 27, 2012, 06:03:21 pm
flowmastergfunk
  • 129
« Reply #9 on: September 27, 2012, 06:03:21 pm »
got picked up by a local today. Cheers!
